Old 08-17-2013, 09:41 AM   #16
civic_eater
civic_eater's Avatar
Ok so i know how to splice my m50 harness in to the e30 fusebox but what do i dowith the harness coming from the passenger side?can i get rid of it or do i need it for the swap aswell?
civic_eater is offline   Reply With Quote
Old 08-17-2013, 10:40 AM   #17
cormier
cormier's Avatar
Instead of splicing into-- you're going to make a connector right? The other plug is a diagnostic connector or auto tranny harness
Old 08-18-2013, 01:35 AM   #18
civic_eater
Ok so motor is out now what do i do with the m20 harness coming out the passenger side do i need it?
Old 08-18-2013, 02:03 AM   #19
oldschool
E30M52 project
Your going to hook up your engine harness to that harness coming from the passe get side... So yes you need it.. Cut the end of the m20 engine harness (connector) and you will need a chassis harness connector from what ever car your new engine is from.
oldschool is offline   Reply With Quote
Old 08-18-2013, 11:43 AM   #20
cormier
cormier's Avatar
Dude you better take pictures and look up the process, you can easily get those connectors mixed up. Show us what you mena
Old 08-22-2013, 10:22 AM   #21
Roysneon
Roysneon's Avatar
Cut the connector plus a few inches of wires off of your m20 engine harness, then do the same for the m50. Match functions, solder, heat shirk, then go vroom vroom.
Actually, I would suggest doing one wire at a time on the m52 side to avoid too much confusion of a dozen cut wires staring at you.
