Old 07-28-2013, 05:36 PM   #1
starscream
1995 325is Incomplete Track Car/Parts/Shell
Alrighty... so the original idea was to get this car and turn it into a track car. I was going through it and it was taking longer then expected, and now as of recent I have some other obligations and ideas and this has to go.
The car is being sold as is, it is no street able at the moment and I am clearly disclosing that.
It was in the middle of being prepped for a track car, and is not completely ready yet for track use as there still is work that needs to be done.
The engine/transmission is in good condition and was working great when I pulled it off the road and in the garage for the track prep. It does have a lot of good parts on it, and I at the moment don't have the time to part it. So I would rather just sell it as 1 item.
It cannot start as there is no battery, and I was in the process of doing the coolant reroute as I removed the heatercore and the rad.
I would probably say this is good as a parts car or to just get the parts that are good off it. It is basically stripped in the interior and the exterior does need some work. Again being that it was supposed to be a track car most of the stuff (heater core, stereo, HVAC controls, etc) have been removed.
Here as some quick notes about the car:
-Interior stripped, does come with the dashboard, cluster, and most switches.
-Has 2 manual cloth seats with frame rails
-Had rust on the driver side footwell, Welded in a metal plate to cover
-Sunroof has been removed and welded a plate over it to block it
-Some of the larger rust spots on the outside of the car have been fixed/bondo/fiberglass resin fixed and painted flat primer black
-Comes with:
Bilstein Shocks/Springs
Turner Motorsports Rear Trailing Arms
Caster/Camber Plates in the front
Rear shock tower mounts
Control Arms with new bushings
Supersprint Catback Exhaust
Kosei K1 Silver 17" Rims
Hankook RS3 Tires (these were brandnew, haven't even seen a day on the track with them)
-New but Not Installed:
URO Metal Thermostat Housing
URO Water Pump
URP Aluminum Waterpump Pulley
Hood Shocks
2 Bottles of Water Wetter
Intake Manifold Gaskets
Upper and Lower Goodyear Radhoses
-Used but Not Installed
Spare front and rear bumpers
Misc parts around the car
Grill (not the kidneys, but where you mount the kidneys too the metal part that's just above bumper)
Selling everything (the whole lot) for $2000.
Not looking to part out at this time, however depending on how much interest there is on the parts I might do that however I would need to get approval from the Mods as I understand.
I'll attach some pics as well.
starscream - 2007 Mazdaspeed 3
starscream is offline   Reply With Quote
Old 07-28-2013, 05:37 PM   #2
starscream
Old 05-04-2014, 01:51 AM   #3
starscream
BUMP!
Selling for 1500 OBO. Need my garage space back lol.
Old 05-04-2014, 02:33 AM   #4
Ziploc
More info on the wheels/tires?
Ziploc is offline   Reply With Quote
Old 05-04-2014, 06:14 AM   #5
haikara2308
1995 325is
Do you have the m50 manifold, projector headlights,an autoclimate hvac or unused 90mm wheel studs.
haikara2308 is offline   Reply With Quote
Old 05-04-2014, 10:22 AM   #6
2str836
Build in progress
I'll take the rear camber arms and front camber plates
'98 328i'
/OO\(lll)(lll)/OO\
2str836 is offline   Reply With Quote
Old 05-04-2014, 10:47 PM   #7
starscream
Kosei K1 in 17 inch with Hankook RS3 Tires
It does have the M50 manifold, no to the projector lights and interior is stripped, only the aftermarket longer studs.
and to everyone else. NOT parting out yet, when I do I'll have a separate partout thread for that. Right now trying to sell as a whole.
Old 05-06-2014, 08:32 AM   #8
haikara2308
What are the dimensions of the Kosei rims, size of the rubber and the manufactured date.
Old 05-06-2014, 11:41 AM   #9
nate_s89
PMed
nate_s89 is offline   Reply With Quote
Old 05-06-2014, 08:56 PM   #10
starscream
tentatively sold....pending this weekend.
Old 05-11-2014, 10:32 PM   #11
starscream
Sold!
mods can close thread.
