Old 07-23-2013, 01:18 PM   #1
polarsnowbea
Maintenance for E90 and headlight bulb
Hi guys,
I can't find any information for preventive maintenance schedule for my '08 3er. mine has about 60,000kms and Im wondering if should I need to change the following:
- Transmission fluid
- Power steering fluid
- differential fluid
- fuel filter
- Cabin filter
- change brakes ( brakes still has about 20,000kms based on on board computer)
I was told by the dealer that my transmission fluid doesn't need to be changed until 100k as well as the power steering.
What do you think?
Also I would love to change my E90's halogen headlights to a superwhite ones. any brand would you guys recommend? or this is a no go?
Thanks so much
polarsnowbea is offline   Reply With Quote
Old 09-08-2013, 09:41 AM   #2
Ali-323i
Ali-323i's Avatar
Stay away from the halogen bulbs found at CTC or walmart (unless they are standard replacements, not ultra white).
For 'high-end' bulbs, there are plenty of options if you search. Xenesis is an example that comes to mind.
Ali-323i is offline   Reply With Quote
Old 09-08-2013, 11:51 AM   #3
jcr
for inexpensive white bulbs you can look into the GP Thunder Bulbs
jcr is offline   Reply With Quote
Old 11-06-2014, 04:01 PM   #4
dieselgg
For any future readers, the OEM halogen bulbs are $10 each at Amazon.ca in comparison to Cdn Tire, which sells them for $20 each. I thought about the GP Thunder bulb, but I was not confident as to how long they would last. I read max 6 months.
dieselgg is offline   Reply With Quote
