Old 07-21-2013, 08:30 PM   #1
Beemsboy27
Mash it up
Beemsboy27's Avatar
Please Help: no crank
So i have a 92 318is 5 manual i had her sitting for about a week and a half then went to go and start her with no crank the battery is fairly new. All the lights come on and when i turn the key nothing happened no crank the light didn't dim i'm thinking its the starter relay but i have really had time to dive in anybody else have any ideas before i open a can of worms?
Thankss
Beemsboy27 is offline   Reply With Quote
Old 07-21-2013, 09:21 PM   #2
Ceeker
first and foremost: ALWAYS check your fuses first.
Check ground straps.a bad or broken engine to body ground will cause short.
check to make sure you're battery cables are secured well on the posts. loose or un tightened cables will also cause problems.
could also be the ignition switch.
I'd start there...
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-22-2013, 08:06 PM   #3
BmW1819
jump start
Old 07-22-2013, 09:49 PM   #4
Beemsboy27
Mash it up
Beemsboy27's Avatar
jump start?
Old 07-23-2013, 12:30 AM   #5
cormier
cormier's Avatar
^^ .... You DID try boosting the car before posting riiiggghhhhttt ? Roll start even?
Old 07-23-2013, 09:06 AM   #6
Beemsboy27
Mash it up
Beemsboy27's Avatar
Havent even had a chance to its blocked in right now
Old 07-30-2013, 03:14 PM   #7
Beemsboy27
Mash it up
Beemsboy27's Avatar
so got her out tried bump starting, checked the fuses and the crank sensor. I have no power on the crank sensor but my starter relay is clicking. Ideas?
Old 08-02-2013, 11:52 PM   #8
ScotcH
Did you try boosting? These things are sensitive to having low voltage.
Old 08-02-2013, 11:55 PM   #9
Beemsboy27
Mash it up
Beemsboy27's Avatar
tried boosting got nothing. i pulled the battery and took it partsource to let it charge going to get t tomorrow and see what happens. lights dim like its drawing power but nothing happens i dont even get the fuel pump going
Old 08-02-2013, 11:58 PM   #10
Beemsboy27
Mash it up
Beemsboy27's Avatar
been running test off the relays and fuses but still nothing
