Old 07-20-2013, 10:21 PM   #1
crunkd
bad gas at Shell
i just filled up at hurontario and ray lawson .. and went through the light and my car stalled and wont hold idle... im thinking the bad storm we had let water into there system...fack!!
crunkd is offline   Reply With Quote
Old 07-21-2013, 01:40 AM   #2
jabela
It wouldn't be the first time Shell had bad gas. However it could be a coincidence. We're any other cars stalling after filling up there? If it was full of water, the station would be full of dead cars.
Your symptoms could be a failing fuel pump which would be due given your car's age. I just went through this a few months ago. Has your fuel pump or filter ever been changed?
www.maisonapothecare.ca
Old 07-21-2013, 01:53 PM   #3
crunkd
Your right it was a mere coincidence. .the fuel pump fuse blew...the fuel pump is a week old...so I'm not sure what's goin on
Sent from BimmerApp mobile app
Old 07-21-2013, 06:03 PM   #4
jabela
Was the filter also changed? If not it could be restricting the pump causing it to overload and blew the fuse. Otherwise it could be a faulty pump, or more likely a bad installation. A bad or corroded connectors. Our some kind of blockage.
Old 07-21-2013, 08:19 PM   #5
Blackedout95
Test fuel pressure once the pump is running again as you stated a fuse blew.
E46
Old 07-22-2013, 09:37 PM   #6
crunkd
The filter was changed 2 yrs ago...car drives but not as great as before...will check fuel pressure thx
