Old 06-29-2013, 05:40 AM   #1
DET1990
zookeeper and det1990 m3 rear end conversion
started yesterday, the car is a 2002 325i we are working on putting a m3 rear end in it to get the lsd and the lower gear ratio. So far we have removed the the stock rear subframe, m3 subframe should go in today
DET1990 is offline   Reply With Quote
Old 06-29-2013, 09:31 PM   #2
DET1990
finished putting it in today. the drive shaft will need to be lengthened, and the aluminium support brace that is on the front 2 diff bolts need to be changed or modified to work. but its going pretty smoothy
Old 06-29-2013, 11:18 PM   #3
Nice job! Props for doing it on jack stands in the driveway!
Brings back lots of memories!!!
Old 06-30-2013, 09:07 PM   #4
DET1990
checked the drive shaft today to see how much it needs to be lengthened its going to need 5 inches also anyone needing parts from the stock rear subframe we are parting it message for details
Old 07-09-2013, 06:30 PM   #5
DET1990
found out the hard way that the m3 drive shaft front flange is bigger than the 325 flange so the modified drive shaft didnt work the drive shaft is now getting the 325 front flange put on
Old 07-11-2013, 09:24 PM   #6
ZooKeeper
Finally got everything put back together today. Drive shaft finally finished. The length it needs to be lengthened is 5 inches if you aren't using the 6 speed tranny. Everything works great just need to get an alignment tomorrow. Just that my cluster is a Christmas light lol the traction control is always off the abs light is on the hand brake light is always on. Any one know why or how this could be fixed ? Would it be because the m3 and the 325 wiring is different ? But here are some pictures of the finished project
ZooKeeper is offline   Reply With Quote
Old 07-11-2013, 09:26 PM   #7
ZooKeeper
Had to reverse mount the bolts on the flange that connects te drive shaft to the guibo because the new drive shaft was to thick and the bolts wouldn't fit through the right side. No problems drive shaft is still balanced
Old 07-11-2013, 09:28 PM   #8
ZooKeeper
Everything put back together
Old 07-11-2013, 09:29 PM   #9
ZooKeeper
New rims being put on
Old 07-11-2013, 09:30 PM   #10
ZooKeeper
And she's done all washed up ready for the midnight cruise tomorrow
Old 07-12-2013, 01:20 AM   #11
Haha, this is only a Supercharger away from being just like my old coupe! (that and Mtech)...
Think about it, almost 290WHP...And I have it for sale!
Old 07-14-2013, 08:04 AM   #12
colombiano
Props for DIY! Did you get the lights figured out? Where did you source the new driveshaft.
colombiano is offline   Reply With Quote
Old 07-14-2013, 08:24 AM   #13
DET1990
The drive shaft is from pats driveline in mississauga
Old 07-14-2013, 11:21 AM   #14
ZooKeeper
The drive shaft was lengthened at drive products but the proper flange was put on at pats drive line since drive products wouldn't do it. And no haven't figured out the lights yet , car drives fine with them on will look into it soon though
