Old 07-30-2013, 03:42 PM   #16
mr ilia
Right on!
Originally Posted by Eurostyle View Post
The ICV will NOT give any codes, the engine will just die...Or have bad idle.
Sounds like a low voltage situation...When alternator goes, it will set off A LOT of codes, including ABS ASC/DSC transmission, radio malfunctions etc...
The MAF can also cause some of this...
Op, likely your battery or alternator are going.
Edit - just noticed the op changed the battery...now it is likely time for an alternator.
Old 07-30-2013, 04:03 PM   #17
jabela
When you charged the battery, did you top off the cells with distilled water?
www.maisonapothecare.ca
Old 08-17-2013, 09:45 AM   #18
Noxas
Ordered a new maf. Brought it to a mechanic and they said 80% of the problem is most likely occurring from that. The alternator is charging the battery fine; I think it was just the fact it was the original battery which might have been putting it off for awhile. Will update once new maf is installed
Noxas is offline   Reply With Quote
Old 08-17-2013, 09:49 AM   #19
Noxas
I've also checked all the hoses when I was taking the icv out; ill check the ccv as well though.
Mind you this was an escalated problem. It fhappened once or twice when I got the car then the symptoms began to get worse. My opinion was a faulty maf sensor.
And that sucking noise was never there before though; even another friend of mine with an e46 whose doing work on his stated the same thing. It's not on his as well. I am going to run a smoke test at my friends shop however once I get the chance.
Old 08-26-2013, 11:40 PM   #20
Noxas
Switched the maf sensor. Almost all errors disappeared except for p1500. Car still hits limp mode. I replaced my icv too but maybe possible it's broken as well? Is there any way to check?
Thank you
Old 09-03-2013, 12:34 AM   #21
Noxas
Sorry; didn't see this. No I didn't. But I also switched the battery around with a working one after.
Idle is extremely rough; when it is really bad you can see the lights dimming in and out inside the car.
Trying to find a test for the maf and icv. Also going to try and get an alternator test as well
Old 10-18-2013, 02:34 PM   #22
Noxas
Thanks for everyone that attempted in helping me figure this out. It ended up; to my luck that the 2nd icv was also faulty. We used several obd scanners in which they all pointed to a mechanical failure in the icv.
tried a third one And everything was all bells and whistles.
Thanks again'
