Go Back   maXbimmer Forums > General > BMW Club of Canada
Old 06-24-2013, 07:00 PM   #16
EMPOWERD
EMPOWERD's Avatar
Event results will be posted on this thread once Jon Abela figures everything out.
My YouTube video
-- RANDY SPARRE --
Old 06-25-2013, 02:48 PM   #17
jabela
Here are the results. Let me know if you find any mistakes. Thanks Randy for another great event!
www.maisonapothecare.ca
Old 06-25-2013, 03:13 PM   #18
jabela
Here's a few videos.
Old 06-25-2013, 11:07 PM   #19
70cruiser
Wow jabela, that is amazing! Great videos, after watching your line through a few of the corners I can see where I'm losing some time, but not near enough to get anywhere even close to you! Seriously impressive.
Steve- Autoslalom rookie
70cruiser is offline   Reply With Quote
Old 06-26-2013, 12:13 AM   #20
jabela
Thanks, I really felt on the ball that day. Amazing what a good night's sleep will do
You're line in the video looked pretty good.
Some things to think about are to straighten out the chicanes, widen the corners, and try to late apex corners before straights. Also try and get as close to the cones as you can. You should be hitting some occasionally if your getting close to them. Also you can play with your tire pressures to improve grip and balance. Good high performance summer tires help too. Were you on winter tires?
Old 06-26-2013, 08:04 AM   #21
70cruiser
Thanks! I will try playing with tire pressures, but without really knowing what I'm doing it's tough. This is my daily driver (70 MPG) and so I just kept the tires at 40 like I always run. They are just cheap motomaster 175/70/13 all seasons. Do I basically want to widen most corners, or are there some where staying tight is better?
Old 06-26-2013, 08:44 AM   #22
Awesome runs Jon, FTD
Old 06-26-2013, 10:15 AM   #23
jabela
I run 40/32 psi front/rear on my 3300 lb car, so you could probably go quite a bit less on yours. Your tires are pretty tall though, so just reduce pressure until you start rolling onto the sidewalls. That should give you max grip from the tires.
Thanks t.dot. Where have you been? Haven't seen you in a while.
I just bought some coilovers so I'll be moving to STX class when I install them and I'll probably be slower while I figure them out.
Old 06-26-2013, 10:28 AM   #24
Curious... what puts Graeme's car in EP?
Old 06-26-2013, 10:41 AM   #25
I signed up for baseball this year, and it's taking up my Sundays. I'll try to make the Bimmercruise event.
What coils did you go with?
Old 06-26-2013, 10:50 AM   #26
jabela
I went with the ISC N1 from bimmerworld. Hopefully they're decent.
Old 06-26-2013, 10:53 AM   #27
jabela
I didn't class him so I'm not sure. What mods does he have?
Old 06-26-2013, 11:33 AM   #28
Just an S52 swap as far as I know. I would think he'd be in SM.
