Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 06-18-2013, 09:34 AM   #1
tigster
tigster's Avatar
JB Racing Lightweight (10lbs) Aluminum Flywheel
Flywheel came out of my 97 M3 (Fitment guide at the bottom of page)
The flywheel can be like new for $150 (you send it in to JBR and they will fit a new friction plate and ship it back to you)
I have already contacted them, and here's their reply
Priced for a quick sale: $150
Thanks for your contact and interest in maintaining your flywheel. All JBR Aluminum Flywheels are serviceable – the procedure and cost for this service is outlined below:
FW Rebuilding Service/Repair
All JB Racing lightweight aluminum flywheels may be renewed via our flat-fee ($150.00) re-building service. This service includes a thorough inspection of your flywheel core, replacement of the worn friction surface with new hardware, new pressure plate installation hardware (except ULTRA-LITE's) and finally, re-balanced to insure the most trouble free operation. Should a more extensive repair be necessary- such as heli-coil threads replacement, ring gear, ignition trigger or any other damage repair be required an additional charge(s) will apply. Our normal in-house turn around time is 24-48 hours.
If you wish to have your flywheel refurbished, package it carefully and send to my attention at the address below. You should enclose a note INSIDE THE BOX with your complete return shipping information and phone number so I may contact you after we have completed the inspection of your flywheel to confirm the repairs necessary. I will collect the applicable billing information from you at that time so we may process your order. Should you have any questions, please contact me at your convenience.
NOTE: Please retain (do not send) the hardened Bolt-Ring & Flywheel-to-Crankshaft Bolts as they are premium grade 10.9 hardware and should be used to re-install the flywheel. This hardware is MANDATORY for proper installation of your JBR flywheel. Replacement Bolt-Ring kits are available and sell for $50.00 each.
JB Racing, Inc.
527 Southridge Industrial Drive
Tavares, FL 32778
Should you have any questions, please let me know.
Thanks,
Dennis R. King
Sales & Marketing Mgr.
JB Racing, Inc.
PH: 352-343-8900 / Fax: 352-343-8174
www.jbracing.com
Fitment:
1992 - 95 E36 M3 w/ S50 3.0L - 6 cyl.
1995 - 99 E36 M3 w/ S52 3.2L - 6 cyl.
Lightweight Aluminum flywheel replaces stock dual-mass flywheel. Accepts OEM clutch/pressure plate/throw-out bearing components as well as performance aftermarket direct replacements. Will also accept many aftermarket sprung-hub clutch discs. Provides improved throttle response and increased performance. For a complete flywheel/ sprung-hub performance clutch kit - see PN 520-010S-S855
520-010-240 Clutch Diameter: 240mm OEM Flywheel Wt. 25.0 lbs.
List Price $646.00 Alum. Flywheel Wt. 10.0 lbs.
Order JBR p/n 520-010-240 Price: $532.00
Today is the tomorrow you worried about yesterday.
tigster is offline   Reply With Quote
Old 06-26-2013, 02:35 PM   #2
knightowl
bump for a good seller!
knightowl is offline   Reply With Quote
Old 07-02-2013, 09:46 AM   #3
tigster
tigster's Avatar
Old 07-17-2013, 10:13 AM   #4
tigster
tigster's Avatar
bump
Old 08-08-2013, 09:48 PM   #5
tigster
tigster's Avatar
Bump
Old 08-25-2013, 09:46 PM   #6
tigster
tigster's Avatar
Sold
