Old 08-13-2013, 11:15 AM   #16
Nerk
Nerk's Avatar
Oh... I should probably not leaving people hanging here...
I figured it out... almost ashamed to admit it... it was simply the ignition coil, 1 bolt and 2 wires later, I swapped in the one from my track car and everything is fine...
all that for something so simple... Doh!
live and learn...
Old 08-13-2013, 11:21 AM   #17
DIY
Permanently Dirty
DIY's Avatar
Originally Posted by DIY View Post
I had something veeeeery similar recently .. Turned out my suspension had rattled the ground wire loose from the shock tower.. And another wire from my coil pack! ... Look at those good because I went through a ecu, fuel pressure and also just replaced the injectors and ignition syst. I also had instanced where it would work one day and not the next, for a period it would run fine, and then just stop. I didn't notice it was wires until I was stuck on the side of the highway where my motor just wouldn't fire ... So check your wires!
BAM!!! Lol
Old 08-13-2013, 11:32 AM   #18
Nerk
Nerk's Avatar
Oh, I thought you were talking about the ground wires
and, to be fair, it wasn't the ignition wires, it was the ignition coil not feeding the ignition wires
but yeah, I know a couple people have told me to do this... I had a tester and everything, but didn't have another set of eyes to watch for the spark as someone else turned the key...
