Old 06-06-2013, 05:13 PM   #1
jabela
Alternator and/or Battery issue?
So, I'm driving home the other day and my radio starts cutting out. I get home, check the voltage while running and it's at 11.7V
So this looks like a bad alternator regulator.
However, I let it cool down and start up, and it was showing 14V for one minute, then went down to 11.7V My guess is that the regulator overheats, or the brushes gave a little life before dying again.
Another thing, I filled up the battery cells with water, and have been charging it for 2 days but it's only at 80% charge. Battery gone too? It's only a few years old, but maybe the bad alternator killed it.
Anyone have a Bosch alternator or just the regulator they can lend me? I ordered one but it won't be here till next week.
Thanks!
www.maisonapothecare.ca
Old 06-06-2013, 06:21 PM   #2
Replace the alternator and see how the battery does, my guess is that it will recover if only a few years old...
Also get a battery load tester/charging system tester, they are under $50 and will take the guessing out of the job.
Old 06-06-2013, 06:28 PM   #3
jabela
I have an intelligent tester just like this one below. Maybe it's just reconditioning the battery. I'll see what state it's at when I get home. Alternator could have been bad for a while...
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old 06-07-2013, 12:03 AM   #4
windwagen
windwagen's Avatar
Loose belt?
Old 06-07-2013, 12:17 AM   #5
Originally Posted by windwagen View Post
Loose belt?
20 years ago, maybe! Not with todays systems!
Old 06-07-2013, 02:21 AM   #6
jabela
Took it apart, brushes are definitely too worn. You can see that one is much shorter than the other.
Old 06-08-2013, 09:37 AM   #7
pawelgawel
If the regulator didnt solve the issue, check your ignition switch.. clean it up and reconnect evefything. I chased a similar issue for days and it was the ignition switch
Sent from BimmerApp mobile app
pawelgawel is offline   Reply With Quote
Old 06-09-2013, 01:28 AM   #8
jabela
Wow, ignition switch gave you low voltages? Must have driven you crazy looking for that.
So, installed new regulator and all is well. It's making 14.1V while running.
Got the new regulator at Oakville Starter Alternator http://www.oakvillestarteralternatorlimited.ca/
The guy offered me a chinese made one for $50 or a Bosch UK made one for $100. I read bad things about the chinese units, so went for the Bosch.
Guy said Budd's buys the chinese units from him with no problems... I'm sure they still charge $800 for it. Yet another reason to avoid the stealerhip.
Posting image of new regulator, which has an updated part number.
new Bosch BR14-M1 F 00M 145 360
old Bosch BR140-M1-V14 F 00M 145 251
Old 06-09-2013, 08:59 AM   #9
windwagen
windwagen's Avatar
nice job - thanks for the tip!
Old 06-09-2013, 10:59 AM   #10
pawelgawel
Damn.. $100 for the rectangular plug??? You can get this for $50 on line np. I replaced mine (oval) that was close to impossible to find for $90... when searching for this, everyone had the rectangular.
Old 06-09-2013, 11:00 AM   #11
pawelgawel
And yes... ignition switch was not even close on my mind. Took it to a shop and got raped!
Old 06-09-2013, 11:29 AM   #12
jabela
Where can you get Bosch made in UK regulators for $50? I could get made in China version for $50.
Anyhow $50 is with having it right away.
One other important tip, the back ventilation cover of me alternator was full of leaves, which probably overheated the regulator and speed up its failure, so clean yours out if you haven't lately. I'm going to look at putting a screen on the inlet to block this debris from causing issues.
