Old 05-31-2013, 05:58 PM   #16
doogee
doogee's Avatar
Good news is the O2 sensor wasn't a waste of money. Brought the HC down quite a bit!
Dakar M3 Track Build Thread
Old 06-04-2013, 05:48 PM   #17
egye30
egye30's Avatar
I guess you guys are not alone.. I went this afternoon and failed too.
Aced everything but the hydrocarbon at idle, didn't miss it by much too. A little background about my test, I ran it on a day new oil change with 94 octane after a nice 30-45 minute drive on the highway so it was nice and hot when it came in. I ran the car as a 325i but I'm running an obd1 M52 with headers m50 manifold m3 cams and a chipped m50 ecu (413) supporting all the mods. I have a stock m50 ecu with a stock chip would it possibly help me pass if i used that or will that only make it worse? Also the tech there said maybe next time I should let it cool down before they run the test as apparently some cars tend to do better when cooler.. could this be the case? Any feedback is appreciated guys I wanna try and squeeze it by since I'm this close rather than going through the hassle of going for a hot rod status test.
1990 325i Sterling Silver Metallic/Black leather.
M52B28 OBD-I W/ S52 Cams, M50 Manifold, SS Headers, Kamotors v5 CAI, Stage 2 F1 clutch w/ 14lb chromoly flywheel, Mark D chip tune.
Bilstein Sports with H&R Race springs + E90 drop hats, F+R Strut bars, '04 330ci Steering rack (3.0 Lock to lock, 13:1), 3.15 Z3 Torsen LSD.
BBS RS's 16x8 front 16x9 rears 205/45 215/45
Old 06-05-2013, 07:31 AM   #18
richie_s999
Stock chip may help, it could be a timing thing, I had to run the stock chip on my old e36 to get it to pass the old test.
Old 06-05-2013, 07:31 AM   #19
richie_s999
Question, how are they going to test all these new cars that don't idle but shut off ???
Old 06-05-2013, 08:28 AM   #20
They are just hooking up to the OBDII port on new cars and reading codes. There is no 2 speed idle for new cars.
Old 06-05-2013, 08:36 AM   #21
My car tests better hotter, and I think that would be the case for a lot of cars actually because when the air temps get high the computer pulls fuel and the car runs a bit leaner.
Usually if your car is a running a bit too rich the e-test machine thinks it's not warmed up yet and makes you do the 120 second warm up cycle.
Also, is your car tuned for 94 octane? If not I wouldn't run it because the higher the octane the slower the burn... slower burn means the possibility of incomplete combustion... incomplete combustion means higher HC readings.
Old 06-05-2013, 04:54 PM   #22
egye30
egye30's Avatar
The car is tuned for 91 octane, I usually like to run 94 because the car seems to idle and run a little better on it so I figured it might be better to run it for the etest as well. Do you think it might be worth a shot running a retest on 91 or will it not make enough difference?
Old 06-05-2013, 04:57 PM   #23
richie_s999
Octane rating has nothing to do with hydrocarbons, you want to drop hydrocarbons toss a couple litres of methonal ( 2-3 litres to a 60l tank).
Old 06-05-2013, 05:42 PM   #24
egye30
egye30's Avatar
You think that will work to squeeze a pass out? Where do I find it around here.
Old 06-05-2013, 06:11 PM   #25
richie_s999
It might, I'd run your tank down to half and toss one litre in, then after the test fill up to dilute it
Canadian tire has it, they sell it for stove fuel for boats and trailers
Old 06-05-2013, 06:29 PM   #26
I explained exactly what octane rating has to do with HC readings....
Old 06-05-2013, 07:07 PM   #27
richie_s999
With drive clean I've seen no difference on testing, it's the same as a hot or cold day, I was one of the first 50 certified testers in Ontario, to squeak by on HC when other levels are good the methonal hydrate actually works.
Old 06-05-2013, 10:37 PM   #28
I was referring to my comments with respect to octane rating and high HC reading.
With regards to temperature, I was referring to engine temp, not ambient air temp. When I was running the stock motor and DME with only a MarkD chip my car failed the first run, then it got hot during the "warm up cycle"... like 3/4 mark hot (because it had no clutch fan at the time) and it passed well within the limits.
Old 06-05-2013, 11:21 PM   #29
richie_s999
High engine or running temps seem less of a concern now that no NO is being measured. Hot running cars usually would get the HC down but fail the NO
The methyol hydrate will get temps up a bit and runs so clean I don't think it produces any detectable HC on it own.
His nominal difference it will help
Dave's car, that's another story.
Old 06-06-2013, 09:45 AM   #30
davericher20
black and blue
davericher20's Avatar
So, looks like its my dist. Cap or rotor.
Its a misfire, wasnt getting fuel on #3 cylinder, pulled the plug wire and the car would idle the exact same, also was a hundred degree difference from the other cylinders (infrared gun)
spark plug is firing. No fuel?
Changed the injector and spark plug, still firing, but idling the same when we pull the wire. Jump the wire from another car and same thing.
Ill clean the contact points on the cap and rotor and see if that makes a difference. But it makes sense I would fail with high hydrocarbons because theres a shitload of unburnt fuel escaping. Duh.
If its not that then I am stuck. I will report back.
