Old 05-29-2013, 09:19 AM   #1
BMe30
all by chance...
BMe30's Avatar
Rev it up!
A little clip of my itb set up.
http://youtu.be/uPNYFYNqcJ4
Just need to make some time for a little dyno tuning for wot ignition timing
Gone but not forgotten
Old 05-30-2013, 05:26 PM   #2
mr ilia
Nice. What is a turnerpro?
How do you plan to do etest with this whole setup?
2004 BMW 325i, sedan, 5spd.
Old 05-30-2013, 09:03 PM   #3
BMe30
all by chance...
BMe30's Avatar
Tunerpro is a free tuning software program. You do however need to buy ostrich 2.0 hardware to plug into the ecu. You will also need an xdf file to translate the bin file to tune with.
It has its ups and downs... So far the only down side is that you still need to run the afm. The plus side is you have full tuning control just as a full standalone system.
Since the car is a 91 i fall under the 2 speed idle test. So as long as im running clean during the 2 idle tests i should be fine. I plan on having an emissions tune to upload when the time comes.
Old 05-31-2013, 10:39 AM   #4
mr ilia
How much did Ostrich 2.0 cost you?
Old 05-31-2013, 11:36 AM   #5
NOTORIOUS VR
NOTORIOUS VR's Avatar
hard to see, but it looks like you have the stock barn door (AFM/flapper) still there after the air filter?
If so can I ask why? all that work to put ITB's and a nice plenum and then put that restriction in front?
Old 05-31-2013, 11:39 AM   #6
You shouldn't have a problem, I almost passed this morning with no ICV and a cam
http://www.maxbimmer.com/forums/show...4&postcount=11
I believe he's planning on converting over to stand alone eventually, but in the mean time on the stock DME he still needs the AFM for the car to run.
Old 05-31-2013, 12:08 PM   #7
BMe30
all by chance...
BMe30's Avatar
http://www.moates.net/ostrich-20-the...eed-p-169.html
Old 05-31-2013, 12:15 PM   #8
BMe30
all by chance...
BMe30's Avatar
Fair question. It was cheaper at the time to go with tunerpro rt / ostrich 2.0 to tune my car instead of going full standalone.
After i build another m42 with a sport cam and higher cr im going to go full standalone and bigger itbs with a pretty funky itb mount manifold... Here's the hint "pulse chambers". Ive seen them on the stock m42 intake manifold. But where my jaw dropped was when i saw the pulse chamber on a m10 race motor with side draft carbs and pulse chambers on the header!
Crazy
Old 05-31-2013, 12:32 PM   #9
mr ilia
Can you also get a wire harness to set it up w/o messing with stock wiring?
Old 05-31-2013, 12:38 PM   #10
NOTORIOUS VR
Crazy
I was under the assumption that some people were able to get a MAF in place of the AFM (maybe hit up some of the guys on E30tech.com who have done just that (on an M20 ECU).
Otherwise it looks like a nice setup!
Old 05-31-2013, 12:48 PM   #11
SiR
Vtec just kicked in
great diy set up. love this kind of stuff
-||Old Crayons||-
Old 05-31-2013, 01:10 PM   #12
BMe30
all by chance...
BMe30's Avatar
It plugs into the ecu where a performace chip would go. It uses all the stock sensors
VR : Miller tried to build a maf conversion for the m42 but dropped it. There is another guy who is taking up the maf challenge in cali for the m42.
Bulletride: what was your emissions results? Easy tune to pass?
Old 05-31-2013, 01:27 PM   #13
See the post I linked.
Old 05-31-2013, 01:41 PM   #14
BMe30
all by chance...
BMe30's Avatar
My bad
Old 05-31-2013, 02:21 PM   #15
mr ilia
Sorry, want to clarify, are you saying it is plug and play as it is? No cutting and soldering will be required?
