Old 07-16-2013, 11:54 PM   #1
E30Jack
auto to 5 speed swap
hey guys/gals, recently picked up a clean 1991 325i 2 dr coupe from the original owner, with only 58k miles on it, was the lady's pavement princess. everything stock, no leaks, & believe it or not...no rust! & i just replaced the timing belt yesterday . only issue is, it's an automatic. i'm wondering what are all the parts i'll need for a 5 speed swap? i have come up with a *mock* list of what i think ill need, can anyone add to it or edit it?
- 260 getrag manual tranny
- master cylinder
- slave cylinder
- brake cylinder reservoir w/ outlet to clutch master
- clutch fork
- drive shaft
- pedal assembly w/ bracket
- shifter
- flywheel w/ bolts, center ring, and cross member
- clutch disk
-pressure plate
am i forgetting anything? please let me know as i'd like to tackle this project asap!
E30Jack is offline   Reply With Quote
Old 07-17-2013, 08:09 AM   #2
You'll need the clutch line from the master to the slave and reservoir to master.
It's actually a really easy swap, good luck!
Old 07-17-2013, 08:45 AM   #3
richie_s999
The brake resiviour just needs to be cut so the hose goes on
Old 07-18-2013, 02:04 PM   #4
E30Jack
Ah okay any thing else I need? I'm pretty much ordering everything new that I can
Old 07-18-2013, 06:44 PM   #5
Yamahammer
Warlock of the century
Yamahammer's Avatar
Just realize there are some differences year to year. Try to get all the parts off the same car.
Old 07-18-2013, 07:22 PM   #6
E30Jack
That's the hard part thanks for the help friends
Old 07-19-2013, 04:02 AM   #7
E30Jack
Another question...would a 325e transmission work for the 325i? I'm assuming it would if you used the same flywheel/slave from the E...wondering cause I can get a full swap outta an E parts car...
Old 07-19-2013, 06:14 AM   #8
richie_s999
E trans can be used, flywheel is a dual mass on E cars, which you don't want
There is a ton of DIY articles on the swap, which list every part you'll need
Old 07-20-2013, 03:46 AM   #9
E30Jack
Will single mass fit in an E trans?
Old 07-20-2013, 03:48 AM   #10
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Shame you are in Seattle, I have all the parts you need.
Old 07-20-2013, 03:51 AM   #11
E30Jack
I'm actually just about 25 mins south of the border, in Bellingham. But Oaksville is north of Pensylvania right? So I'm still too far haha
Old 07-20-2013, 03:55 AM   #12
Axxe
Axxe's Avatar
Yeah in Ontario, all the way across the continent. I could arrange for reasonable shipping to Vancouver and then you could pick up, but I think that would put my price beyond what you can find locally / lower 48.
