Old 05-14-2013, 01:14 PM   #16
DIY
Permanently Dirty
DIY's Avatar
No error codes, so I presume the mixture is just within the limits otherwise the O2 would set off the engine light..
As for the CTS Ill check that tonight, I got a few spares thankfully. But cold or hot it still happens just at different RPM
Old 05-14-2013, 09:30 PM   #17
DIY
Permanently Dirty
DIY's Avatar
ok so interesting set of developments..
tonight I swapped ECU's first without my EAT chip and since that didnt SOUND much better, i then swapped em ... also seemed like it still wasnt working right.
so I put it back to what I had origonally and it reved fine but wasnt idling smooth .. so I took it around the block a few times, then on the highway ... the whole power band is smooth now so no more jerkin/ misfire..
BUT! now the idle is reeealy irratic and stalls often. Also I am now getting my engine light flickering on when it actually does idle and when driving at constant speed...
tomorrows work:
finally check the AFM, and the CTS ... and I think I got a spare ICV lying around I'll try that too
so maybe my EAT chip was just loose? I dont get it...
thanks for your suggestions so far everyone!!
Old 05-15-2013, 06:46 PM   #18
Deetow
If you need help on the weekend give me a shout. Ill swing by after i get my new brake line in.
Deetow is offline   Reply With Quote
Old 05-15-2013, 09:55 PM   #19
DIY
Permanently Dirty
DIY's Avatar
SUCCESS!!!!
So todayI took out my icv and gave it a cleaning.. my thought is it was jammed open from not having th o2 sensor in for so long .. and that solved my idle issue ( but I still think its not working properly so i'll source a new one when it gets bad again .)
so that and a combination of my EAT chip possibly being loose seemed to have been my problem.
thank you everyone for your help in this matter!!
took it out for a drive today and apart from me needing to adjust my valves it seems to be better
Deetow you are most welcome to come over on saturday! I have an assortment of go fast parts im picking up from buffalo in the mornin ... muahahaha
Old 05-16-2013, 05:43 PM   #20
DIY
Permanently Dirty
DIY's Avatar
Sooo you know how I said it was fixed? ... Yah funny thing ... As I sit here on the so as I sit here on the side of the highway ... Pndering why me .. And wtf I thought this was fixed .. I check something I should have just checked first ...
The real issue was the ground on the shock tower .. Aaaaand! A nut on my coil pack ...
Oh well lesson learned ... Sorry for wasting everybodys time
