Old 05-09-2013, 01:23 PM   #1
tofubomb
tofubomb's Avatar
335xi KW V1s finally installed
Hey guys, finally got around to installing these bad boys after having them sit in my living room for a good 2 months!
Just a quick question for those that also have V1s installed. How low did you set the front and the back?
Also, if anyone is planning to do this setup as well I highly recommend it. I'm also open to answer any install/ride related questions.
tofubomb is offline   Reply With Quote
Old 05-09-2013, 04:13 PM   #2
cormier
cormier's Avatar
How about some pix!
Old 05-10-2013, 10:59 AM   #3
tofubomb
tofubomb's Avatar
Sure! Here's some pics I took this morning.
I'm sure I can go maybe an inch lower front and back, but I think it's not at a bad height right now. I may even raise the back a bit, what do you think?
Old 05-14-2013, 01:37 PM   #4
tofubomb
tofubomb's Avatar
C'mon guys give me some advice/comments! If everyone thinks it's a good height I'm going to get my alignment done! (~13.5" to fender at front, ~13" to fender at rear)
Old 05-14-2013, 02:21 PM   #5
P7X
Looks good man!
Equal gap around the wheel looks the best IMO
P7X is offline   Reply With Quote
Old 05-14-2013, 02:32 PM   #6
damameke
a little lower, front and back and with spacers,
the stance will be better...
Old 05-14-2013, 03:18 PM   #7
cormier
cormier's Avatar
Your pictures are also upside down!
Old 05-14-2013, 08:22 PM   #8
matryx
Like what damameke said drop it a bit lower and with some spacers will make it look even better.
Just wondering how's the ride quality compared to stock?
matryx is offline   Reply With Quote
Old 05-15-2013, 02:05 PM   #9
tofubomb
tofubomb's Avatar
Thanks for the responses guys!
But it looks fine from my computer
I may have the front down another half inch, only problem may be getting over that ridge at the end of the driveway. I think the rubber bits are scraping already.
Ride quality is much better than stock xDrive IMO. xDrive suspension is floaty and there's quite a bit of travel given that it's taller than a standard RWD. Ride is closer to the sport suspension but maybe a tad stiffer. Handling feels more controllable and response is better, most likely due to the stiffness (cornering is also improved). On the average road it's not a sacrifice of comfort compared to stock. Over bumps the dampening definitely responds better, I always found stock to be very harsh and slow to return over bumps. No weird noises or grinds, clearance is good, and I can throw a hard corner pretty confidently.
Now for the alignment!
Originally Posted by P7X View Post
Looks good man!
Thanks! Yea, don't really want to have it tucked.
Old 05-23-2013, 10:07 AM   #10
tofubomb
tofubomb's Avatar
Okay! I've dropped the front another half inch (didn't have time to do the back) and got my alignment done. Everything in tip top shape now, drives straight and smooth!
