Old 05-05-2013, 12:10 PM   #1
aberg83
aberg83's Avatar
Oil on spark plugs
Pulled a few of my plugs to check condition and discovered that they're covered in oil. The oil appears mainly above the threads (i.e. outside combustion chamber) so I'm thinking maybe a valve cover gasket. Looks like evidence of some oil leaking at the gasket on the outside of the block. Have a look at the attached picture and let me know if you agree or if there's something else this may be. I'll try a compression test too.ImageUploadedByTapatalk 21367770058.034685.jpgImageUploadedByTapatalk 21367770079.575597.jpgImageUploadedByTapatalk 21367770115.736107.jpgImageUploadedByTapatalk 21367770148.309655.jpgImageUploadedByTapatalk 21367770166.995205.jpgImageUploadedByTapatalk 21367770183.675500.jpg
Sent from my iPhone using Tapatalk 2
aberg83 is offline   Reply With Quote
Old 05-05-2013, 12:46 PM   #2
TSI
Reverse Gear Member
Looks like the valve cover gasket to me, at least in part. The stains on the cover and heat shields are telltale.
I would suggest you also check the spark plug leads for damage. Oil like that is really bad for the boots.
TSI is offline   Reply With Quote
Old 05-05-2013, 12:51 PM   #3
aberg83
aberg83's Avatar
Thanks, I'll check out the boots. Looks like the spark plug tip is just showing regular wear.
