Old 05-01-2013, 03:58 AM   #1
SickFinga
SickFinga's Avatar
Coil springs
Does anyone, beside Eibach, sell springs by size?
What I mean is that I can pick spring diameter, length and rate from a catalog
http://performance-suspension.eibach.../ERS-17_US.pdf
I checked H&R and they don't offer anything like it.
Old 05-01-2013, 06:57 AM   #2
Hypercoils and BC Racing lets you specify.
GC gets theirs from Eibach I believe, not sure who ATS uses but I think you can order them from there also.
Old 05-01-2013, 01:01 PM   #3
TheMadChigga
TheMadChigga's Avatar
Ground Control sells springs by sizes and rates, so does Swift Racing, another one is QA1, there are few more but the names skipped my mind.
Old 05-01-2013, 05:43 PM   #4
SickFinga
SickFinga's Avatar
Thanks guys, Hypercoils and Swift Springs have comprehensive catalogs on their website, but they do not have what I'm looking for.
Here is my dilemma.
A 1972 Mercedes weighting 1705kg has stock springs rated at 335lb/in front and 350lb/in rear. This sounds extremely high for a stock spring on car that was designed to be as comfortable as it gets. For example, 850CSi weighting 1890kg has 160lb/in springs in the front. Any idea why there is such a big difference in spring rates? Does suspension design matter in this case? A-arm on the Mercedes and McPherson on the E31?
Old 05-02-2013, 10:23 AM   #5
TSI
Reverse Gear Member
Here is my dilemma.
A 1972 Mercedes weighting 1705kg has stock springs rated at 335lb/in front and 350lb/in rear. This sounds extremely high for a stock spring on car that was designed to be as comfortable as it gets. For example, 850CSi weighting 1890kg has 160lb/ft springs in the front. Any idea why there is such a big difference in spring rates? Does suspension design matter in this case? A-arm on the Mercedes and McPherson on the E31?
I think the Merc ones are softer: 335lb/in as opposed to the 160lf/ft in the E31.
Inches and pounds--huge difference.
TSI is offline   Reply With Quote
Old 05-02-2013, 01:20 PM   #6
SickFinga
SickFinga's Avatar
They are both lb/in. I just made a typo in my original post.
