Go Back   maXbimmer Forums > Classifieds > For Sale > Suspension & Brakes
Old 04-29-2013, 10:05 AM   #1
boro92
E36 Track prep parts
All items are NIB unless otherwise noted:
1) Used S50B32 Oil pan & Dual oil pickup oil pump. Includes all hardware necessary to do the swap (nothing else needed but labor!). All hardware is new, pan/pump is used. --SOLD
2) AKG 95A Diff Bushings + 10.9 grade front diff bolt: $90
3) Bimmerworld Delrin Centered FCAB: $75
4) Mielle HD RTAB & Bimmerworld Limiters: $60
5) Front subframe reinforcement plates: $20
6) Rear trailing arm pocket reinforcement plates: $20
7) Rogue Engineering Tranny Mounts: $40
8) Bimmerworld Track Engine mounts (Group N Reps): $180
9) AKG Rear Subframe Bushings 95A: $160
10) Bimmerworld Dual Fuel Pump fuel starvation kit: $280
11) JT Designs Alloy underpanel + Rad baffle: $100
12) OEM Slat Grille: $50
13) 12mm H&R Spacers w/ Extended bolts: $80
boro92 is offline   Reply With Quote
Old 04-29-2013, 02:55 PM   #2
dcramer
Dual fuel pump kit still available ?
Old 04-29-2013, 03:39 PM   #3
boro92
Dave, pumps are available.
They're NIP. It's the bimmerworld stage II pump kit.
Old 04-29-2013, 03:40 PM   #4
dcramer
I sent you a PM, lets exchange numbes over PM
Old 04-29-2013, 04:02 PM   #5
boro92
Dual Fuel pump kit Sold!!
Old 04-30-2013, 02:29 PM   #6
boro92
Reinforcement plates sold!
Old 05-07-2013, 10:10 AM   #7
BostonGreen
Hey I messaged you regarding item number 6...I haven't heard back from you. Are they available? Please let me know.
BostonGreen is offline   Reply With Quote
Old 05-07-2013, 10:25 AM   #8
boro92
Sorry!
I just PM'd you back. We'll be in touch.
PS - item 6 is sold (RTAB reinforcements).
I believe you were asking about the RTAB bushings + limiter kit (item#4)
Old 05-24-2013, 11:18 AM   #9
boro92
Below are the items left:
1) AKG 95A Diff Bushings + 10.9 grade front diff bolt: $90
2) Bimmerworld Delrin Centered FCAB: $75
3) Mielle HD RTAB: $40
4) AKG Rear Subframe Bushings 95A: $160
5) JT Designs Alloy underpanel + Rad baffle: $100
6) OEM Slat Grille: $50
7) 12mm H&R Spacers w/ Extended bolts: $80
