Old 04-29-2013, 01:37 AM   #1
JTRACKER
Question D1S Replacement - Failure
I had a driver side low beam failing (purple) so bought a pair of replacement D1S bulbs.
Problem now is both sides are dead and can't see anything that would cause this failure.
Everything I'm reading suggests ballast failures, but that makes no sense that both sides would fail after bulb replacement.
Any suggestions?
Thanks,
JT
JTRACKER is offline   Reply With Quote
Old 06-27-2013, 12:36 AM   #2
DimSumE90
Ballast failures happen when the bulb is no good.
A quality bulb will last years with the original ballast. I have driven my car since 06' and I have changed the bulbs once till date.
www.littlebimmer.com
DimSumE90 is offline   Reply With Quote
Old 06-27-2013, 04:11 PM   #3
98RACE
I had some knock off Phillips that craped out may ballast. Found a guy with a rebuilt ballast and installed that and a fresh set of Morimoto's and no issues since.
98RACE is offline   Reply With Quote
Old 07-04-2013, 05:17 PM   #4
Kaotikmike
How low can you go ;)
It's 100% your ballast I change those out atless 3 times a week do to cheap ass china bulbs if u need any ballast or work done let me know as I did over 60 E90 E91 to date meaning swapping out the ballast or retrofitting them with OEM Osram or AL ballast
Kaotikmike is offline   Reply With Quote
Old 07-04-2013, 05:18 PM   #5
Kaotikmike
All so sell original OEM D1S Osram bulbs at a fraction of the price u would pay at the dealer
