Old 04-22-2013, 03:46 PM   #1
kruler
Bilstein PSS10 install question
About to install PSS10s on my M3 and not sure what OE parts are reused. I know that the spring perch and bearing (#6 in diagram) stay, but not sure about the upper spring pad (#7). Anybody know?
kruler is offline   Reply With Quote
Old 04-28-2013, 11:08 AM   #2
pawelgawel
everything is reused other then the spring and shock. just install the hats same way as on the original set up (-) the bump stops (abviously)
pawelgawel is offline   Reply With Quote
Old 04-28-2013, 12:34 PM   #3
kruler
Should have mentioned that I am installing with Ground Control camber plates. From another forum I've learned that the spring perch and pad are both reused.
