Old 04-22-2013, 12:45 PM   #1
Basketcase..
Scumbag
Bridgestone Potenza RE050A RFT
90-95% tread! Almost new! Run flats, never get stranded with a flat again!
"The Potenza RE050A RFT (Run-Flat Tire) is Bridgestone’s Max Performance Summer run-flat tire developed exclusively for specific BMW, Ferrari, Mazda and MINI vehicles. The Potenza RE050A RFT is designed to provide temporary extended mobility for a distance of 50 miles at up to 50 mph even after a puncture has allowed complete air pressure loss. The Potenza RE050A RFT was developed to provide good traction along with responsive and predictable dry and wet road handling. It is not intended to be driven in near-freezing temperatures, through snow or on ice.
The Potenza RE050A RFT features a high-grip tread compound molded into an asymmetric tread design. Stable outboard shoulder elements, intermediate tread blocks and a continuous center rib provide responsive handling, high-speed stability and traction on dry roads, while circumferential and lateral tread grooves pump water out from under the tire's footprint to minimize hydroplaning and aid wet traction. A continuous rib adjacent to the inboard shoulder promotes even wear and resists inside wear generated by suspensions that specify negative camber alignment settings."
Located in Alliston. Work in Toronto. Can deliver possibly for the right price! $700 OBO over $1200 new minimum!
Basketcase.. is offline   Reply With Quote
Old 04-22-2013, 12:59 PM   #2
BMWdouche
Not Banned... Yet
BMWdouche's Avatar
Sizes?
BMWdouche is offline   Reply With Quote
Old 04-22-2013, 03:47 PM   #3
Basketcase..
Scumbag
225/35/18 and 245/35/18. Sorry haha
