Old 04-29-2013, 12:37 PM   #1
dcramer
e36 fuel starvation solutions
With the new S50B32 and the new asphalt at Mosport I now experience fuel starvation between 3 and 4.
A little bit of googling suggests that pre-96 this was not a problem as there was a pickup in the left tank as well as the right. My guess is some bean counter figured this wasn't really necessary and they switched to a single pickup.
There are a few kits out there with dual fuel pumps, and one which is just the pre-96 setup.
The question is: is the pre-96 setup good enough ? I dislike the complexity of 2 fuel pumps even though it is actually cheaper at bimmerworld.
Dave
Old 04-29-2013, 01:01 PM   #2
Discostar
Discostar's Avatar
I have never had a problem at the track, even at 1/4 tank. My friends 97 cant go below a 1/3rd tank before it starts having starvation problems.
That said, I still would never go below a 1/4 tank.
Old 04-29-2013, 01:29 PM   #3
dcramer
It might have something to do with driving style too.
I don't starve through 8 but my foot isn't in it like between 3 and 4
Old 04-29-2013, 01:51 PM   #4
Discostar
Discostar's Avatar
lol. I thought you might bring that up.
We both have plenty of track time, formal training, and our lap times are very similar.
That said. If you are spending a lot of time at the track, why not just go for the extra pump. Perhaps someone can chime in who has it done. They aren’t all that complicated and I have heard nothing but good things from those who have done it.
Old 04-29-2013, 01:55 PM   #5
dcramer
Well if I just don't accelerate as hard between 3 and 4 it's fine, plus this didn't happen at all with the S52. I am curious why it seems to happen to some cars and not others, I wonder if the siphon tubes get dislodged or something.
I am considering the dual pumps, but I'm cheap. Course my penny pinching may cost me a motor if I'm not careful
Old 04-29-2013, 02:10 PM   #6
This happens to ALL e36's 96+ no questions asked. On my E36 M3 trackcar, I first tried the older system from the 92-95 and it still starved! Between 3 and 4 just like you. Usually around 1/2 a tank.
It wasn't until I put a second pump in the driver side until the problem was solved and I could run until empty.
Here are some solutions. Don't skimp, just go straight for the dual pump setup. It's really easy to install too!
For $320 you can't really go wrong.
http://store.bimmerworld.com/e36-fue...-kits-p39.aspx
http://store.vacmotorsports.com/vac-...-kit-p562.aspx
Old 04-29-2013, 02:11 PM   #7
dcramer
that's all I wanted to know,
Thanks!
Old 04-29-2013, 02:18 PM   #8
Even better, someone on the forum is selling a kit!
http://maxbimmer.com/forums/showthread.php?t=157311
Old 04-29-2013, 02:56 PM   #9
dcramer
How lucky is that...thx
Old 04-29-2013, 03:46 PM   #10
SiR
Vtec just kicked in
how are you enjoying the swap?
-||Old Crayons||-
Old 04-29-2013, 03:55 PM   #11
dcramer
Loving it. 250 miles on Friday, not a drop of oil used.
Found a small coolant leak Saturday when I looked in the garage. The plastic line for bleeding the rad is supposed to have a brass insert, the heat from the rad shrank the tubing under the clamp.
thank god for the new asphalt as I was into turns a "wee" bit faster than I thought I was.
Buddy has a cayman R, I was able to pull away from him above 100MPH
Old 04-30-2013, 09:40 AM   #12
SiR
Vtec just kicked in
oh thats sweet. It definitely is a different experience especially above 90ish mph. It just keeps pulling. Feels great on the back straight at mosport.
Maybe one day I can get to a swap like that (or s54).
-||Old Crayons||-
Old 04-30-2013, 09:48 AM   #13
dcramer
So actually it was a cayman S, but still.
Ya the motor is completely smooth, no vanos kick. Little strange bouncing off the rev limiter between 3 and 4. Will take a bit of getting used to.
Old 04-30-2013, 09:53 AM   #14
NOTORIOUS VR
NOTORIOUS VR's Avatar
For that amount of money, I would do a surge tank instead.
I'm going to have to look into this issue as well, definitely cannot afford to starve the motor under boost.
Old 05-01-2013, 02:35 PM   #15
rafiki
210k and counting
rafiki's Avatar
I had the same issue with my E46 - '01 330i. Not sure about E46 tank setup vs. E36, but replacing the fuel filter solved my fuel starvation issues between turns 3 & 4 at Mosport.
'01 330i premium package - sahara beige on tan - oe clears - legal tint - manual tranny minus cdv - carbonio intake - aluminum strut bar - sport shocks with h&r springs - uuc camber kit, ss lines, tse3 & evo3 ssk+dssr+rob knob - shark injected
rafiki is offline   Reply With Quote
