Go Back   maXbimmer Forums > Specific Regional Areas > Windsor, Ontario
Old 04-19-2013, 08:16 PM   #1
Bmuxxx
Bmuxxx's Avatar
Etest
Does anyone know anybody that can help out with an etest for a price?? Can't get my e30 to pass
Bmuxxx is offline   Reply With Quote
Old 04-19-2013, 08:26 PM   #2
Blades
Your opinion is to long
Blades's Avatar
Canada now has officials to watch via camera of the whole emissions test and its about $3000+ to make them look the other way or turn off the camera
Good luck .. Better off making it stock and putting everything back again
-=[ BL/\DES ]=-
Old 04-30-2013, 06:10 PM   #3
lost
lost's Avatar
Plate it in a location in Ontario that doesn't need an e-test... Will mean new address on drivers license though.
lost is offline   Reply With Quote
Old 04-30-2013, 08:41 PM   #4
Trekz
post youre results
Trekz is offline   Reply With Quote
Old 05-01-2013, 09:37 AM   #5
TSI
Reverse Gear Member
If it's too high hydrocarbons, induce a vacuum leak and spray some water mist into said leak before the test.
Cheap water injection ftw!
TSI is online now   Reply With Quote
Old 05-07-2013, 10:50 AM   #6
lost
lost's Avatar
Just had my ford excursion done and passed fine, however I didn't have to do the new way as it's and ODB1 so I had to do a two speed idle test (similar to old) but a bonus is they jacked up the output numbers, so it's easier to pass. I also spoke to them about a car failing, and it was identified that the max an individual needs to spend to rectify the problem is $450 and then they will be granted a conditional pass, which is good for another two years. So realistically, say you fail, you spend $450 on oil change, fluid flush, tune up, etc., spending $450 and you're good to go.
Old 05-07-2013, 04:29 PM   #7
Effay
Effay's Avatar
heard if you have a swapped engine its game over, im talking obdII new test style
Effay is offline   Reply With Quote
Old 05-21-2013, 04:25 PM   #8
firbster
post up your results what did it fail on ?
firbster is offline   Reply With Quote
Old 05-22-2013, 07:32 PM   #9
Bmuxxx
Bmuxxx's Avatar
Sorry havent had a chance to get on here. hydro carbons were through the roof. limits were 200, and i was putting out anywhere between 3100-4000 haha horrible, but we got a pass now and im on the road!!!
Old 08-31-2013, 08:55 PM   #10
bart325is
IH8BART
e-test???? What's that????
e30 less
bart325is is offline   Reply With Quote
