Old 05-01-2013, 09:22 AM   #16
dd330i
O2 sensor?
dd330i is offline   Reply With Quote
Old 05-17-2013, 02:59 PM   #17
johnbmw
I need a good BMW mechanic.. someone who knows these cars inside out.
I just finished spending $2800.00 and the problems is still there.
Replaced by BMW..
fuel pump
repair kit version
return pipe
guide tube
o ring
vacuum hose
vent hose
dipstick
adjuster unit
johnbmw is offline   Reply With Quote
Old 05-17-2013, 03:08 PM   #18
johnbmw
This is a reply to erostyle:
These were all checked as well.
I would look for vacume leaks, sometimes under hard acceleration the engine will move (also check engine mounts!) and a cracked intake boot will suck in air...causing a missfire.
Also check camshaft sensors, they tend to do the same.
Old 05-17-2013, 05:19 PM   #19
Dinanstu
Get the codes.
I still believe its electronic and the ECU is putting the car in limp home mode. Yours is AWD, so it could be a tranny safem mode...
Guessing isn't helpful, get the codes.
So to recap, the car always loses power when you turn into corners and never at any other time?
Did I mention to get the codes?
Old 05-17-2013, 06:40 PM   #20
damameke
Replaced by BMW..
fuel pump
repair kit version
return pipe
guide tube
o ring
vacuum hose
vent hose
dipstick
adjuster unit
If I spent that much money and the repair was based on what you have told them, and it was not resolved.. I would be speaking to the service manager, before I opt for indy...which dealership is that?; so I know where not to go....
Old 05-24-2013, 03:17 PM   #21
johnbmw
Problem fixed:
Here Guys, if you ever experience an issue like this.
It turned out to be my coils. 4 out of 6 were misfiring on hard acceleration so the chip shut them down. By restarting the car it cleard the fault.
Well I'm back on the road again and can finally pass a Hyundai.
Thanks for all your advise.
Old 05-24-2013, 10:40 PM   #22
windwagen
windwagen's Avatar
Please tell me the dealer didn't charge for the non fixes!
