Old 04-18-2013, 12:29 PM   #1
TSI
Reverse Gear Member
help with gas tank
Trying to replace my leaky tank...
Got exhaust, driveshaft, lines everything off, but I can't drop the tank itself. The two rear bolts are hopelessly rusted, even rounded (evil, evil salt). As you may know, there isn't much space to work with...any ideas?
TSI is online now   Reply With Quote
Old 04-18-2013, 12:59 PM   #2
richie_s999
Vise grips above the rear subframe
Or hammer on a socket, extension with flex joint might fit
Ratcheting wrench helps on the back bolt
If none of that works, you may have to drop the subframe
Old 04-18-2013, 02:21 PM   #3
TSI
Reverse Gear Member
Damn, I was hoping it wouldn't come to dropping the subframe...thanks for the advice, I'll try that.
Old 04-18-2013, 02:36 PM   #4
Make sure to use an impact gun if you have one. I dropped my tank last week and if I had used a ratchet on my rusted bolts I would have stripped them for sure because with the impact gun I was sitting there hammering each bolt for about a 30 seconds before they'd even move.
Old 04-18-2013, 03:20 PM   #5
TSI
Reverse Gear Member
None available, but how the hell did you manage to fit an impact gun anywhere near there? I can barely fit a socket extension...
I'm guessing you have a hoist.
Old 04-18-2013, 03:50 PM   #6
I happened to have my subframe out at the time, it does make the job much easier ...assuming you've had your subframe off recently and it's not seized to the body of the car lol
I wish I had a hoist...
Old 04-18-2013, 06:05 PM   #7
TSI
Reverse Gear Member
We're talking about a $400 beater here...so it's all jammed up. I guess I'll try sawing it off, and fab up another attachment point. I got a nut splitter, but I'm not sure if it's a nut or bolt head on the bottom (I had two bolts and one nut on the fronts, the rears are too cooroded to tell.
In other news, I am jealous of your ground clearance (nice pic too!)
Old 04-19-2013, 02:39 PM   #8
TSI
Reverse Gear Member
Victory on the bolts...
Now, the tank is loose (everything disconnected), but I can't get it to drop. It seems that there isn't space betwen the crossmember and th footwell to get it out!
Again, any ideas?
Old 04-19-2013, 04:08 PM   #9
Ceeker
try sliding it towards the rear of the car and then dipping the front down. but it might also working lowering one side.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 04-19-2013, 04:14 PM   #10
TSI
Reverse Gear Member
Yup. Got under it and wiggled, no go. Then I tried judiciously applying some hammer, and it fell right out. Awesome!
Now, gotta put everything back and replace the shocks.
Old 04-19-2013, 04:26 PM   #11
Ceeker
I'd check the brake like junction while everything is out. that short line is VERY common for rotting out. It's easiest to replace if you have the subframe slightly dropped. also rust coat the area under the tank. lots of moisture gets trapped up there. main reason for the tank rot to begin with. also sent you a pm. you gave me the wrong number..lol
Old 04-20-2013, 10:27 AM   #12
TSI
Reverse Gear Member
New tank is in and connected! Now to replace the driveshaft and exhaust...but not too tight, as I'll have to take it all out again to replace the CSB in two weeks.
