Old 04-14-2013, 01:33 PM   #1
goldhawk
Steering rack relocation
I'm working on my motor swap and got to test fit the motor this weekend - found a few problems I wasnt expecting.
Main problem is that the starter is going to interfere with the steering rack, where the column enters the rack.
So, does anyone here know where I can find an example of someone moving the rack location?
I did a check on e30tech and R3V and havent seen anything so far. I figure maybe there would be something buried within a build thread.
I know that moving the rack will mess up the steering geometry, bump steer etc, but if this motor is gonna fit there's no option, cause the starter isnt moving...
I also know that I can space the subframe down (essentially lift the body) which would help with my problems, just looking for other options as well.
goldhawk is offline   Reply With Quote
Old 04-15-2013, 09:35 AM   #2
cormier
cormier's Avatar
How much more clearance do you need? What motor?
Old 04-15-2013, 10:43 AM   #3
RHD conversion
Old 04-15-2013, 01:26 PM   #4
goldhawk
Its an ecotec lnf motor from a Pontiac Solstice.
I have to do the oil pan clearance stuff before I know exactly how much it has to move, but approx 2 or maybe 1in down, and 1" closer to the firewall would also help.
RHD conversion
yeah... but then I'd have downpipe issues... guess I could just run it out the hood like a derby car though... :-)
Old 04-15-2013, 03:00 PM   #5
Ceeker
man you better get the specs right..it's not a "sorta thing..." changes a lot of things.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 04-15-2013, 03:31 PM   #6
cormier
cormier's Avatar
What motor and trans mounts are you using? Custom anyways no? Can't you just move the motor whoever you want it to sit lol?
Old 04-15-2013, 08:27 PM   #7
_JohnnyD_
_JohnnyD_'s Avatar
I would suggest you cut out the firewall and move the engine far enough back to clear the starter. Building a new firewall would be easier than trying to move the steering rack inches and still get the suspension geometry somewhat right.
Good luck.
“Life is a series of experiences, each one of which makes us bigger, even though sometimes it is hard to realize this...”
Henry Ford
_JohnnyD_ is offline   Reply With Quote
Old 04-15-2013, 10:01 PM   #8
goldhawk
Yes, I know this. I'll be taking exact measurements. I'm just looking for ideas right now as to other peoples experiences and see what has been done to figure out my best option.
Solstice GXP motor. Yep, custom mounts.
As it sits right now the trans shifter lines up very good with the hole in the tunnel, and the oil pan sump is sitting right infront of the steering rack, so there would be less modifying those things. (Yes, I know there are ways to get the shifter to work if it doesnt line up.
I'd rather not cut the firewall if nessecary, I'd like to keep the dash and heater core etc all intact. Also, the brake booster would be in the way if I move it back (has a high pressure fuel pump on the back of the intake cam)
