Old 04-12-2013, 10:27 AM   #46
m3dragon
Events Guy
So I did something stupid. I made it so I do not have to smog the car anymore but in order to do that I needed to so one last smog test. Well because of a minor oversight on my part, I was thrown into the idle and 2500 idle test group. In years past, I was able to pass the smog text because of yee old friend pictured below. The test was the rolling 20mph and 30mph tests. I passed with race software, 100 cell race cats and all the other intake / engine mods. All you need it the blue and orange can to make any car pass the sniffer =)
As I have to do the idle test, I fail that by 19 points but pass the 2500 test better than a Prius LOL. So I am off Friday to get a test section to pass the idle part only. This will be the last time is have to smog whoohooo.
Still waiting on the cam from Bekkers so I can start putting all the goodies on. Trying to time it to be done all at once as the car will be mostly apart.
Oh and the car just went over 59K finally =)
m3dragon is offline   Reply With Quote
Old 04-12-2013, 10:28 AM   #47
m3dragon
Events Guy
HOLLY COW. Finally after almost a year I have both cams at last.
Car is going in to have sub frame reinforcement installed and diff upgraded. After that it is going in for the intake and cam install FINALLY.
Old 04-12-2013, 10:34 AM   #48
JJJames
+ E91 328xi 6 speed
JJJames's Avatar
Jesus christ man, thats awesome/ambitious - may be presumptuous to ask but what is all this gonna cost?
JJJames is offline   Reply With Quote
Old 04-12-2013, 10:38 AM   #49
m3dragon
Events Guy
I am off tomorrow to get the car smoged for the last time hopefully. I had an O2 go out just before I had a test section made. The last few week I have had o drive the car around with a test section in that is bouncing around a little under the car. It is freaking me out a bit that it is going to break something as there none of the brackets are installed. Car hates having to work through 100 cell race cats and 2 high efficiency cats. Car is also being dropped off tomorrow for rear sub frame and diff upgrade to 3.91s
So I have had some parts installed a tad out of order. I had custom seat brackets made to have the Recaro seats installed. I had to have them made as I am using the sliders so the wife can drive the car still. I sit about the same height as the stock power seats. The goal was to drop weight and sit lower. I could get about a inch lower if I went to a non fixed slider but as mentioned above the wife needs to drive the car. Here are some quick pics of the seats installed.
Can you say Pile Of Parts!
Old 04-12-2013, 10:39 AM   #50
m3dragon
Events Guy
Car is back after being gone for the weekend. So here is the latest and greatest.
Got the car smogged for the last time WOOTTT. As you can see I am cleaner than a prius… 4 cats can do that HAHA. Anyone needs a test section I will loan it out for $30 bucks.
After I got the car smogged I took it straight over to the fabrication shop to have the rear sub frame done as well as have the diff upgraded to 3.91 gears. Trying to time work when things can be done together. My car had started to show signs of spider cracks on both sides. The frame had not "completely cracked" but if I had not done the reinforce kit it would have eventually done so. Here is some images of the car at the fabrication shop.
From what I have found and what the shop believes as well is the reason the frames are cracking is fatigue failures. Same issue with aircraft hulls and the pressure changes. The metal eventually begins to fracture with the constant pressurization and un-pressurization.
The fatigue part in our cars is the loading and unloading going around turns. This constant flexing causes the area to fail. Bad job by BMW not to beef this up for that is the reason for the cracks. Stiffer suspension only acerbates the issue faster. As the car has 59000 hard miles on it from back roads driving and being on CA roads I guess I am not surprised to know I would potently have the issue.
Last of the recent changes is the 3.91 gears upgrade. Already I can feel a change in the car and I don’t even have them broken in. I t made sense to do the diff work now as I had the sub frame out. Pics are of the old 3.61 stock gears.
Old 04-12-2013, 10:39 AM   #51
m3dragon
Events Guy
Loaded all the parts up and car is off to the shop to get all the major goodies installed. I will post some more images of the parts later tonight. Never got around to doing detailed images like I wanted to but at least I have images of everything before it goes on the car.
Old 04-12-2013, 10:40 AM   #52
m3dragon
Events Guy
I know most of you have seen these parts before but here are the parts at some different angles. Hopefully you will see some things you never noticed before. Such as the center console has some side flares that I never noticed in the images I have seen. I grouped the images based on item.
CSL Intake Main Air Collector images
Old 04-12-2013, 10:41 AM   #53
m3dragon
Events Guy
Old 04-12-2013, 10:41 AM   #54
m3dragon
Events Guy
Old 04-12-2013, 10:42 AM   #55
m3dragon
Events Guy
CSL Intake Unfiltered Housing
Old 04-12-2013, 10:42 AM   #56
m3dragon
Events Guy
Snorkel Housing
Old 04-12-2013, 10:43 AM   #57
m3dragon
Events Guy
Old 04-12-2013, 10:44 AM   #58
m3dragon
Events Guy
CSL Center Console
Old 04-12-2013, 10:44 AM   #59
m3dragon
Events Guy
CSL Cams – Actual part number ID
Old 04-12-2013, 10:45 AM   #60
m3dragon
Events Guy
The car is now back at home after two months of being on vacation LOL. The shop I took the car to was kind enough to take images of some of the work as they did it. I need to give a major kudos to the shop for doing the work and doing an AMAZING job.
IPB-Autosport - Independent Sacramento Audi, Porsche, BMW, Mini, VW Specialist.
Address: 1206 C St, Sacramento, CA 95814
Phone: 916-453-1465
They had to do some learning in order to put it all together as well as do some customizing in order to make a factory fit and finish. They made it all come together so if you want to do something crazy like this in CA than this is the shop. They also have all the Evolve stuff as well as they programed the car for me. Next step is to paint the front bumper and break in the diff and cams for 500 miles =)
Car the day before surgery
No the images you all have been waiting for. Here is a LARGE compilation of images of an OE CSL INTAKE, OE CSL Air duct, and OE CSL Cams install. I will make NO apologize for the in-depth amount of images of the install done. Thank you again to the shop for taking the time to document =)
