Old 04-11-2013, 02:03 PM   #1
oldschool
E30M52 project
-$20- FREE E30/E36 parts
Parts i no longer need on my e30... (This Is not a partout)
(1991 318is)
Sway bars (front and rear) free
Gas tank (no leaks) $20
Full exhaust (new after cat)$20
M42 engine (running with good compression...200k) $20
M42 maf free
E30 shifter linkages free
E30 drive shaft free
Steering Wheel (3spoke) gone!
E36 1999 328is
Clutch assembly (flywheel, friction plate, pressure plate) $20
Obd2 exhaust manifolds free
Obd2 emission stuff free ( no air pump)
AC compressor (with bracket) $20
Obd2 intake manifold (with throttle body and traction control) $20
Obd2 wiring harness free
Green top injectors 19.5 lbs. (i think) $20
Im sure i have more parts, Ill update when i find them.
All prices negotiable.
Thanks for looking
oldschool is offline   Reply With Quote
Old 04-11-2013, 02:37 PM   #2
defaultName
I'll take the steering wheel and MAF. I'd like the exhaust but I don't think it will fit in my car...
Old 04-11-2013, 03:10 PM   #3
Do you have an OBDII Secondary Air Pump? Is that part of:
If so ill take it.
Old 04-11-2013, 03:34 PM   #4
El Gato Liso
El Gato Liso's Avatar
Got the brake booster and master cylinder for the e36? Let me know and consider it sold please!
R.I.P. E30
Old 04-11-2013, 04:15 PM   #5
oldschool
E30M52 project
I'll cut the exhaust in half for you...
No air pump sorry...
No brake booster sorry...
Steering wheel gone already...
Old 04-11-2013, 06:19 PM   #6
e30_kid89
The Afro-stig
e30_kid89's Avatar
If that obd2 harness is uncut I'll take it!
Old 04-11-2013, 08:25 PM   #7
poolays
poolays's Avatar
Ill take the e36 flywheel. Pm sent
poolays is offline   Reply With Quote
Old 04-11-2013, 09:03 PM   #8
oldschool
E30M52 project
****UPDATE**** NEW PARTS
Obd2 exhaust manifold... Gone
Clutch assembly... Gone
Shifter linkage... Gone
Driveshaft... Gone
Steering wheel... Gone
Wire harness... Gone
All other parts available
Just found....*** 1999 328is M52 b28 oil pan...$20****
E30 tranny mounts free
E36 tranny mounts free
Will keep you posted
Old 04-11-2013, 09:18 PM   #9
BMWe30325ic
Hey do you have stock sway bars? and where are you located i am extremely interested
BMWe30325ic is offline   Reply With Quote
Old 04-12-2013, 03:48 PM   #10
oldschool
E30M52 project
Sway bars, holding for,someone
Engine. Holding for someone
Pan is gone
Old 04-12-2013, 03:53 PM   #11
oldschool
E30M52 project
I also have an m50 running motor on stand... $350 obo would be nice
AKG aluminum e30 24vavle swap engine mounts as well. 80$
Old 04-13-2013, 11:00 AM   #12
oldschool
E30M52 project
Custom made aluminum hubcentric spacer for e30
25mm thick
4x100
Pair of 2
Made to fit diamond racing steelies over the rx7 4pot brakes.
Can be redrilled to anything tho
100
Old 04-21-2013, 03:50 PM   #13
nate_s89
Do you have an M52 windage tray by any chance?
nate_s89 is offline   Reply With Quote
Old 04-21-2013, 09:15 PM   #14
aristo
Would you happen to have any of the Oxygen sensors? If so, interested.
let me know, thanks.
edit ** for the m52.
aristo is offline   Reply With Quote
Old 04-24-2013, 05:42 PM   #15
oldschool
E30M52 project
Windage tray I'm assuming is the oil baffle inside the oil pan... Yes I have it.. Free
no o2 sensors.
