Old 05-05-2013, 02:22 PM   #1
El Gato Liso
El Gato Liso's Avatar
OEM PATTERN Lock Bolt Removal
Hi
I have problem. I cannot for the life of me get the lock bolt off. the pattern has been destroyed and rounded out.
Anyway I should go about getting this thing removed?
R.I.P. E30
Old 05-05-2013, 04:34 PM   #2
TSI
Reverse Gear Member
How big is it? How much clearance around the bolt? Got any pics?
I had to deal with a lot of stripped bolts this week, this worked for me: use a grinder to cut a head in the outside surface of the bolt. Even two sides is enough, then get a pipe wrench on it.
For clarity: make the round outside of the bolt into a square/hexagon/circle with two flat sides.
Old 05-05-2013, 05:31 PM   #3
Somehow I don't think he will have enough space for a grinder...
Maybe try a left hand drill bit or screw extraction bit
Old 05-05-2013, 07:46 PM   #4
Beemsboy27
Mash it up
Beemsboy27's Avatar
get a 12 point socket out the size(one with lifetime warranty) slam it on with a hammer and crack it off with a breaker bar. its not going be easy but it'll work
Beemsboy27 is offline   Reply With Quote
Old 05-05-2013, 11:05 PM   #5
El Gato Liso
ok ill give that a try
but i'm pretty sure there is a ring around the head of the bolt to prevent such an event from occuring!
geeez i need to get these off
R.I.P. E30
Old 05-06-2013, 07:52 AM   #6
a di grinder could work with a drill bit type grinder. take some time but eventually you could probably sheer the head off. The other thing already mentioned is the 12 point socket and hammer. lol
Old 05-06-2013, 12:50 PM   #7
El Gato Liso
lol theres a ring around the head that spins freely...to prevent what i would be doing i guess hahaha
R.I.P. E30
Old 05-06-2013, 12:56 PM   #8
Take a dye grinder with a small bit to it and cut the ring off.
