Old 04-06-2013, 03:22 PM   #1
matty.dc
matty.dc's Avatar
Squealing from the tunnel
Last night when I took the car out for the "shakedown" run after installing the s52 I noticed a squealing sound coming from underneath the shifter in the tranny tunnel somewhere. The sound starts at 30km/h and is very faint above 100km/h.
Any suggestions/ experiences?
Matt
2013 Ford Edge - Daily Driver
Old 04-06-2013, 05:00 PM   #2
El Gato Liso
El Gato Liso's Avatar
same thing happened to me with my m52 swap
its the tranny whining for some weird reason. didn't happen til post swap
R.I.P. E30
Old 04-06-2013, 05:28 PM   #3
matty.dc
matty.dc's Avatar
This is more like a bearing noise and not a whine. Right now I'm leaning towards the centre support and bearing.
Old 04-07-2013, 12:12 PM   #4
Yamahammer
Warlock of the century
Yamahammer's Avatar
I don't think this is your CSB. Sounds like its the input shaft bearing in the trans. When it gets warm it will go away. IMO g260 are not worth rebuilding, live with it or buy a used trans for 100$
I have the same noise in mine when it is colder, maybe taking a video will help us give a more accurate prediction.
Old 04-07-2013, 02:18 PM   #5
matty.dc
matty.dc's Avatar
This is a noise from the output/behind the tranny. I removed the driveshaft today and the CSB did have a grinding noise which as we all know at higher rpm turns into a squeal. If this doesnt fix the problem, I will look at other solutions. The noise remains hot or cold. I will take a video if the problem isnt fixed with this change out.
Old 04-14-2013, 06:10 PM   #6
matty.dc
matty.dc's Avatar
So the end result was............ A combination of a bad bearing and the from dust cover rubbing on and galling the drive shaft in front of the bearing. Replaced the mount and the CSB with a sealed bearing so the dust covers were no longer necessary.
