Old 04-01-2013, 08:42 PM   #1
Tyman
Karter
Tyman's Avatar
Don't know what drive shaft to use
ive got an m52 swapped 318 and have no idea what drive shaft is in it, it vibrates really bad from 30-38 km/h then a bit at 120, the bracket that holds the center bearing is completely broken off on the one side so could that be the problem?
1991 318is S52 Project (Summer Car/Track Car)
1997 Honda Civic B20 Swap (Winter Beater)
Tyman is offline   Reply With Quote
Old 04-01-2013, 09:12 PM   #2
TSI
Reverse Gear Member
That is likely the problem, but if it's been like that for a while you'll probably have other problems with the driveshaft. Do you have any documentation on the swap? Do you know what tranny is in it?
TSI is offline   Reply With Quote
Old 04-01-2013, 09:40 PM   #3
karmatose
164.3ci Of Fury
karmatose's Avatar
I had some driveshaft shake but it was because I had shitty polyurethane transmission bushings that compressed way too much after installation and caused the driveline to be out of alignment at and shake like hell at certain speeds. Swapped driveshafts, guibos and CSBs plus pulled out the diff and inspected it and it still didn't go away.
Just put the new bushings in yesterday (Condor Speed Shop's UHMW bushings) and went for a quick drive. No more vibration. On the up side, I now have a spare everything to do with the driveshaft. Replacing your CSB will likely fix your problem though if it's snapped. Not a fun job, but pretty easy to do.
"She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. " - Han Solo
Old 04-01-2013, 09:46 PM   #4
poolays
poolays's Avatar
iwould say either the broken hanger bearing as you mentioned or a broken / distorted flex disc.
poolays is offline   Reply With Quote
Old 04-04-2013, 08:11 PM   #5
cormier
cormier's Avatar
Your CSB is probably your issue. Guibo may be a good idea to replace while you do it. You can get a new one at Pelican or from Mike@Maranello (easiest sources). If you measure the overall length of your driveshaft, you can probably find out what its from or at least what you need to replace it with should you need to
Old 04-04-2013, 10:52 PM   #6
matty.dc
matty.dc's Avatar
Do you know which transmission was used in the swap?
2013 Ford Edge - Daily Driver
Old 04-05-2013, 10:36 AM   #7
Tyman
Karter
Tyman's Avatar
No idea, how can you tell the difference between the two?
Old 04-05-2013, 10:50 AM   #8
karmatose
164.3ci Of Fury
karmatose's Avatar
Well, on the Getrag 260 on the left side of the transmission when mounted near where the slave cylinder goes, you'll see a part number that begins with 260. This part number is also on the ass end of the transmission too.
I'm not sure what to tell you about the Getrag/ZF options that were available in the E36 because of limited exposure to them.
AFAIK, the later Getrag 240 could have also been used as well (likely if your car stared life as a 318is)
Old 04-05-2013, 11:11 AM   #9
I'd say that's definitely the issue.
Old 04-05-2013, 11:15 AM   #10
karmatose
164.3ci Of Fury
karmatose's Avatar
... and when you replace it, get one of these. It makes the job SOOOOO much easier (says the guy who did it twice last year). Makes getting the inner race off childsplay.
