Old 03-28-2013, 12:36 PM   #46
karmatose
164.3ci Of Fury
karmatose's Avatar
I just slip a box end wrench on the bleeder screw and then put the hose to the catch can over top of it. I can't remember the size of it though. It's been a while.
Old 03-28-2013, 03:09 PM   #47
cormier
cormier's Avatar
I think they're 7mm or 8mm depending on the screw
Old 03-28-2013, 03:17 PM   #48
noid
noid's Avatar
7mm sounds about right.
I encourage the use of a 6 point box end wrench.
Old 03-28-2013, 05:52 PM   #49
mr ilia
It is 7mm, i made it them loose quite easy. Will continue working on this tonight....i already have my subframe bushings in the freezer...
Old 03-28-2013, 09:49 PM   #50
karmatose
164.3ci Of Fury
karmatose's Avatar
Rubber or polly?
Old 03-28-2013, 11:36 PM   #51
mr ilia
all parts are oem rubber....
Finally the end seems to be not far away...I was able to get old bushings out and press the new one's in...I used 6' "C" press from Canadian tire that i got today for about 7$....started putting everything back together. I should be able to be fully done around early afternoon. Will report back.
2004 BMW 325i, sedan, 5spd.
Old 03-29-2013, 08:30 PM   #52
mr ilia
She is finally ready for its first rive after the "rear end" surgery....
guys, thank you for all your help, with out it likely would have been even more painful. Thanks again!
Old 03-29-2013, 08:34 PM   #53
noid
noid's Avatar
Wheres the complimentary rear end (subframe) picture?
Old 03-29-2013, 08:43 PM   #54
mr ilia
lol...I was a little mad at this whole subframe trip, that I was not in any type of mood for the pictures..but, yes, I should've...
The car feels way better now...I got rid of the "diff & drive shaft clunk" betwen the shifts, as well as car no longer pulls to the right....the last test remains to be up for passing, is the "rear end" shake above 120 km/h...
Will test this later tonight.
Old 03-30-2013, 08:13 AM   #55
karmatose
164.3ci Of Fury
karmatose's Avatar
Good stuff. Glad it worked out for you.
Sent from my GT-I9000 using Tapatalk 2
"She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. " - Han Solo
