Old 03-23-2013, 03:59 PM   #1
mr ilia
GTA - rear subframe bushing - where to do? I have parts.
Hi,
I got rear subframe bushings and rear control arm bushings...half way in I realized this is too much for me to do....I put everything back together now....heed help to have it done.
Can some one please direct me to a shop or a person who can change the bushings for the subframe and control arms (all rear)?
All ceased nuts and bolts is not an issue as I already dealt with...I can travel to place to have it done....I will pay cash fir this job.
PM or reply, I would like to do this with in next week.
Help?
2004 BMW 325i, sedan, 5spd.
Old 03-24-2013, 09:03 AM   #2
BMe30
all by chance...
BMe30's Avatar
Rmp did mine.
Gone but not forgotten
Old 03-24-2013, 10:12 AM   #3
kruler
stancefactory will take care of you
kruler is offline   Reply With Quote
Old 03-24-2013, 06:16 PM   #4
mr ilia
what were the prices like to do this job?
Old 03-24-2013, 09:13 PM   #5
frankie591
at least 5 hours of labour I'd bet.
Old 03-24-2013, 09:19 PM   #6
BMe30
all by chance...
BMe30's Avatar
I dont recall. It was 4 years ago and i had other stuff done at the same time.
Give the shops a call.. Get a quote and go from there.
Old 03-25-2013, 08:45 AM   #7
cormier
cormier's Avatar
I wouldn't think so if they're already off the car ready to be pressed
Old 03-25-2013, 10:53 AM   #8
mr ilia
I need full labor here...including full disassembly...I called BMP, but they want to see the car before giving a quate.
Old 03-25-2013, 11:33 AM   #9
Getting it off the car is the hard part. If you don't have access to a press just burn the old bushings out, the new bushings can be pressed in using a piece of threaded rod and a couple of washers and nuts.
Old 03-25-2013, 12:43 PM   #10
mr ilia
This is where I'm with this. The old bushing has ceased to the frame...
It looks like once it get get it loose I will be able to use the heat gun to melt the old part and press it out with the floor jack.
Old 03-25-2013, 01:01 PM   #11
cormier
cormier's Avatar
Have you tried the threaded rod method? Nothing worked for me until that. Mine came off in 15 minutes of that method
Old 03-25-2013, 01:07 PM   #12
^ yup +1
5/8-11 tap into the bushing, screw a bolt into it, then pound it out from inside the car.
Old 03-25-2013, 01:15 PM   #13
noid
noid's Avatar
If you still want to do the job have a look at these two links:
http://www.rtsauto.com/e30-rear-subf...l-and-install/
and
http://www.rtsauto.com/the-easy-way-...-arm-bushings/
If you don't have a vise, go get one, its hands down the most useful tool to have. The bigger the better. I have a ridgid f60, and it has been able to press in/press out anything and everything.
If you are looking to get a brand new vise, I would recommend looking into gray tools. They have very reasonably priced vises. If you are ok with getting a used vise. I know of a place that sells industrial grade vises in hamilton (vises from closed down steel factories) for damn cheap.
Old 03-25-2013, 01:19 PM   #14
mr ilia
I had a plan to go to Brafasco to get 5/8 lag bolt, since Home Depot and Canadian Tire do not carry bigger than 1/2....If I can get the bushing off with this methid, than It should be easy to get the rest of the job done....I will have to do the trailing arm bushings, but I may have some one else do this for me, since I'm no comfirtable disconnecting rear break lines...
Old 03-25-2013, 01:23 PM   #15
cormier
cormier's Avatar
No? It's not hard or anything just be careful not to get fluid everywhere :p
Good time to replace ebrake cables and whatever brake/fuel lines are worn
