Old 03-22-2013, 06:05 PM   #1
///M_AMAZIN
///M_AMAZIN's Avatar
10MM Spacers 5x120
Here are a set of 10MM spacers
Comes with bolts
Great Titanium finish
No Rust
Most common size of spacers used for that great flush look
Spring is here - Don't miss out!
Came off a E46
Located in the heartland area - Mississauga
Can deliver within the area
Willing to clean before sale
Text for inquiries. Call if interested
6472.852IO6
Price $70 O.B.O
SANI
@IAMFNAMAZIN
///M_AMAZIN is offline   Reply With Quote
Old 03-22-2013, 10:51 PM   #2
jskeets
I like to drive fast
jskeets's Avatar
Hey, how long are those bolts that come with it? Are they a decent amount longer than the stock bolts? I wouldn't mind picking this up. I'll pm you if I can get down to your area this weekend.
jskeets is offline   Reply With Quote
Old 03-22-2013, 11:03 PM   #3
Are you sure they are 10mm? Usually 10mm isn't enough to be hub centric. They look more like 12mn or 15mm.
Old 03-23-2013, 11:54 AM   #4
///M_AMAZIN
Yes they are a decent amount longer than stock bolts thus making the spacers fit with the tire. They are designed for this size of spacers to make everything fit.
Well the bore has to be 72 because they fit perfect on the E46, I know its not 74 (fitting for E39). You do not need a hub-centric ring to fit this. They are 10MM
SANI
@IAMFNAMAZIN
Old 03-23-2013, 10:30 PM   #5
jskeets
jskeets's Avatar
PM sent
Old 03-24-2013, 08:00 PM   #6
///M_AMAZIN
SOLD
Thanks for all the interest
SANI
@IAMFNAMAZIN
