Old 03-18-2013, 12:46 AM   #1
Dev
fuel cutoff missfire cyl 2
hello guys i am new to forms i have 2001 bmw 740i that love alot, got codes 1345/1341 miss fire and the computer has shut of fuel for cyl#2/ it jerks at idle/ pls help thank you my new friends
Dev is offline   Reply With Quote
Old 03-18-2013, 01:05 AM   #2
Check all the usual tuneup parts; coils/plugs/sensors...if nothing changes, do a compression test. Not uncommon for those motors to bend a valve and loose all compression in one cylinder, causing missfire (sometimes almost unnoticable in the way engine runs, other than CEL).
Old 03-18-2013, 09:42 AM   #3
Check the MAF!
Follow me on Instagram @SEVEN40iL and Twitter @SEVEN40iL
Old 03-18-2013, 11:13 AM   #4
One way to eliminate it being a coil pack, is to swap coils with another cylinder, clear the codes, if the misfire moved to that cylinder then you can assume you have a bad coil.
If not, you'll need to move onto other potential causes, plugs, bent valves, injectors, etc.
Old 03-18-2013, 04:56 PM   #5
Dev
Thank you my friends, I have changed the plugs, got a new coil pack and check each one all good, checked injector its find, next will do a comp. test and see where we stand. u guys are right its running on 7 cyl. and go like nuts, i love this this car. thank you.
Old 03-18-2013, 04:58 PM   #6
Dev
will check MAP and CPS that has come up in the codes sometimes. thank you
