Old 03-16-2013, 07:07 PM   #1
slammered
2001 e46 battery light issues?? HELPPP
battery light goes on at 2800rpm and up....if i switch gears it goes away, it stays if i hold the throttle??? what could the problem be??
2001 325ci
thanks in advance
slammered is offline   Reply With Quote
Old 03-18-2013, 01:59 PM   #2
pawelgawel
this could be an alternator issue. check the voltage on the battery, make sure it reads over 13 with lights on. if its lower, Id replace the alternator voltage regulator before anything else..
this should help and explain more:
http://forum.e46fanatics.com/showthread.php?t=583423
pawelgawel is offline   Reply With Quote
Old 03-18-2013, 02:48 PM   #3
slammered
the battery is putting out over 13v when its running with the lights, but when i hit 3000rpm, it drops to 11.3v and thats when the battery light goes on, if i let off the throttle it goes back up to 13.8v...should i just replace the alternator??
thanks for your reply
Old 03-18-2013, 08:15 PM   #4
BmW1819
Yes u need a alternator
Old 03-18-2013, 09:17 PM   #5
slammered
thanks for you help, alternator is removed and the new one is ready to be dropped in tomorrow
Old 03-19-2013, 07:35 PM   #6
BmW1819
What make??
Old 03-19-2013, 11:28 PM   #7
slammered
rebuilt oem bosch
