Old 05-15-2003, 12:22 AM   #1
bimmerpwr
wheel spacers
Anybody know where i can get some H&R or other good quality wheel spacers for a reasonable price???
bimmerpwr is offline   Reply With Quote
Old 05-15-2003, 12:25 AM   #2
jeremy
www.bmpd.com they might not be on their website, but they sell h&r and there own bmp spacers
Old 05-23-2003, 12:59 AM   #3
bimmerpwr
ok thanks
Old 05-23-2003, 02:27 AM   #4
WASABI
OG
why do you need/want spacers? for your car? you don't get rubbing yet?
Old 05-23-2003, 05:14 AM   #5
MeAtWork
I am not really technical but I know that when u use wheel spacers there can be some problems.
When I wanted to buy my car there were 4cm spacers in the back and about 2cm in the front, the steering wheel shaked like hell between 80-100km/h when I took a test drive. Not wanted to buy it like that but after the previous owner removed the front wheel spacers and alligned the wheels the problem was solved. Apparently the wheel couldn't turn wright because of the wheel spacers so I would get some good info about this.
Again I'm not a mechanic so maybe someone else knows this better.
E30 Fanatic
MeAtWork is offline   Reply With Quote
Old 05-25-2003, 01:49 PM   #6
bimmerpwr
alright, thanks guys, i just wanted to offset the wheels a little bit more, but i'm not gonna do it anymore if it's gonna cause all these problems.....
Old 05-25-2003, 05:07 PM   #7
jeremy
if you use the proper (h&r/bmp) hub centric spacers that are T.U.V approved you shouldnt encounter these problems..i have been looking into sapcers as well (more wheel options)....pm windsor318 he is running the bmp ones with no problems...
Old 05-25-2003, 05:26 PM   #8
windsor318is
Nitrous Junkie!
windsor318is's Avatar
bimmerpwr, if you just want to bring the rims you have out a bit more, i wouldnt bother. the small spacers (5mm, 10mm) im almost positve dont come hub centric, and you will need longer bolts for it.
Old 05-25-2003, 05:39 PM   #9
Soldo
Soldo's Avatar
Can someone help me, recently i've started to notice my car is rubbing, but its not TOO low, i have the PSS 9's on it, and theres SLIGHT rubbing, both front and back but i only noticed them so far on hard LEFT turns, what can i do to prevent this, ASIDE from a fender roll, would spacers help take away the rubbing!?!
Keven Soldo
Old 05-25-2003, 05:40 PM   #10
jeremy
check out your rear crossmember mounts
Old 05-25-2003, 06:24 PM   #11
Soldo
Soldo's Avatar
care to explain a bit more, what should i look for?!
Thanks!
Old 05-25-2003, 11:57 PM   #12
jim s
Try this place for H&R spacers
I bought my 15mm H&R spacers from these guys.
They are for my E30-M3. I have not noticed any vibrations or
shimy.
They were the lowest price I could find.
Had them in stock...door-to-door.. from California to Toronto in less than 7 days.
http://www.optauto.com/webstore/prod...t=410&last=410
Good luck
jim
jim s is offline   Reply With Quote
Old 05-27-2003, 11:50 PM   #13
bimmerpwr
thanks guys
Old 05-28-2003, 03:27 AM   #14
T-spec
T-spec's Avatar
Wheel spacers move your wheels out closer to the fenders, so no, they wouldn't help your problem, you could add a bit of negative camber but you have to have to buy adj rear control arms and adj front strut mounts which will cost $$$$$$ and you would get increased inner tire wear..
live fast, die quick, drive a bimmer
T-spec is offline   Reply With Quote
Old 05-28-2003, 03:33 AM   #15
Soldo
Soldo's Avatar
so theres NOTHING i can do then, thats weird, cause i was pretty sure that you can run 225/45/18 on a E36, lower it nicely and not get rubbing!
Keven Soldo
