Old 03-10-2013, 10:11 PM   #1
rider-.
o2 simulators for drive clean??
Hey guys
I have to go for an etest soon however my post cat o2 sensors are disconnected since the threads on one of the manifolds came out with one of the sensors after trying to replace them.. After that i just tied them up and kept the o2 sensors disconnected since they have nothing to do with fuel trim. Now with these new obd etests I will not be able to pass! I cant even put the o2 sensor back unless i weld in a new bung since I welded the hole shut after the threads were ruined. My question is that if I were to buy o2 simulators, would it allow my car to pass? Or would the new systems detect some sort of modification.
Old 03-10-2013, 11:11 PM   #2
NOTORIOUS VR
NOTORIOUS VR's Avatar
As long as the simulators are working correctly to allow the ECU to see what it wants to see, the ECU will know no difference and pass the readiness code eventually.
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
Old 03-11-2013, 08:03 AM   #3
JUICY J CAN'T
propr'one's Avatar
^^+1,
Actually probably faster than real O2's, since those have to warm up.
hid headlights
Old 03-11-2013, 10:26 AM   #4
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Honestly, the new OBD e-test just made things a lot easier for people with headers, cat inefficiency codes, or otherwise missing post-cat O2's.
Contact the OP in this thread:
http://forum.e46fanatics.com/showthread.php?t=906094
He will make you a set of O2 simulators with an incorporated special resistor for the heated elements. Just ship him the connector ends of your O2 sensors, and you'll get back a clean plug & play solution shipped to your door.
ac_2007 is online now   Reply With Quote
Old 03-11-2013, 10:55 AM   #5
SiR
Vtec just kicked in
^^^ this. its so much easier now.
You couldnt fake a tail pipe reading before.... but to make those monitors happy? easy. lol such cash grab bs.
-||Old Crayons||-
Old 03-11-2013, 11:44 AM   #6
NOTORIOUS VR
Well that's not really true
Or at least, there are ways to make your car pass the sniffer w/o cats and it is quite simple even.
E36 · VEMS · TUNING
Old 03-11-2013, 12:25 PM   #7
ac_2007
ac_2007's Avatar
Care to elaborate?
I know there are solutions you can run the car on which improve the NOX readings and such, but its not worth potentially causing damage to engine components, peripherals, and mainly rubber-based components just to pass the sniffer test without cats.
The only other 2 (illegal and discouraged) methods are to get "a guy", or have another car of the same make/model which does have cats.
Old 03-11-2013, 01:01 PM   #8
NOTORIOUS VR
Methanol
E36 · VEMS · TUNING
Old 03-11-2013, 01:13 PM   #9
ac_2007
ac_2007's Avatar
As per my reply above then.
Old 03-11-2013, 02:31 PM   #10
JUICY J CAN'T
propr'one's Avatar
you guys are talking about two different things. the OBD system has to report emissions OK and the shiffer test has to pass. alcohol will make your exhaust gasses cleaner, you can use o2 sims and other electronics to pass the OBD test. Im in talks to start selling o2 + secondary airpump simluators, i'll let you guys know if i can beat the current prices.
hid headlights
Old 03-11-2013, 03:15 PM   #11
NOTORIOUS VR
What about your reply? It has nothing to do with anything.
Correct
E36 · VEMS · TUNING
Old 03-11-2013, 05:34 PM   #12
ac_2007
ac_2007's Avatar
The conversation transitioned into passing sniffer-emissions without cats.
"its not worth potentially causing damage to engine components, peripherals, and mainly rubber-based components just to pass the sniffer test without cats"
Old 03-11-2013, 07:54 PM   #13
JUICY J CAN'T
propr'one's Avatar
the right way to get a car to pass driveclean without cats is:
-reinstall cats
-test
-remove cats
You can have a midpipe section that's removable to make it easier for yourself.
BTW high flow cats cause very little backpressure and most people can run cats just fine, they just choose not to because they're stupid.
hid headlights
Old 03-11-2013, 08:54 PM   #14
BMe30
all by chance...
BMe30's Avatar
My high flow cats blew out less than a year... However i did pass emissions last year with my 91' before the insides started to break apart.
I think ill do the cat swap from now on.
Old 03-11-2013, 10:34 PM   #15
NOTORIOUS VR
Annnnnd to that, an 80% mix of Methanol won't do any damage what so ever... for the time you will drive on it to get your sniffer test done.
You fill up with pump gas afterwards and be on your way.
E36 · VEMS · TUNING
