Old 03-09-2013, 12:32 AM   #1
madonthemike
madonthemike's Avatar
LIcense Plate Light Assembly - Corrosion
Hi All,
I just realized that my license plate light holders were corroded to the point where I can no longer place a bulb anymore.
Do you guys just replace the entire assembly? Or can I just buy a metal piece and solder to the remaining contact?
Also how do you remove the assembly? I removed the four torx, but wasnt sure about the harness, can i just pull it out or should it be on the inside of the trunk (after removing carpet lining) ?
Thanks.
madonthemike is offline   Reply With Quote
Old 03-09-2013, 12:49 AM   #2
You have to replace the full thing. On some years the cable is short and can be removed without the carpet, and others you have to...Just try and see.
If you need a good used one, we usualy have them
Old 03-09-2013, 09:09 AM   #3
cormier
cormier's Avatar
New assembly Nd be verreryyyy careful placing the big gasket, it tends to sit not quite right
Old 03-10-2013, 12:33 AM   #4
madonthemike
Could you pls pm me the price for a decent set?
Old 03-21-2013, 05:20 PM   #5
jskeets
I like to drive fast
jskeets's Avatar
Originally Posted by madonthemike View Post
Hi All,
Thanks.
Hey dude, how did you end up with this? Any progress on repairs? A quote? Let me know as I'm now in the same situation
jskeets is offline   Reply With Quote
Old 03-23-2013, 01:35 AM   #6
madonthemike
Well im saving this for a summer project, as a temporary fix i just put a really bright led in the non corroded bulb holder.
How bad is yours?
You can get the whole assembly for about $80 from the ECS
http://www.ecstuning.com/Search/51137170966/ES78260/
Or alternatively i guess you could look at soldering some kind of holder (assuming there is enough contact area left and that circuit continuity is still maintained - check with a multimeter).
Old 03-23-2013, 08:23 AM   #7
cormier
cormier's Avatar
Don't leave it too long -- mine started arcing and caught fire a bit
Old 03-23-2013, 09:30 AM   #8
davericher20
black and blue
davericher20's Avatar
So THAT'S why I see only the back halves of e46s burnt to a crisp at the junkyard. It all makes sense
Old 03-23-2013, 10:14 AM   #9
cormier
cormier's Avatar
^^ haha I never noticed. Wouldn't doubt it, it's quite the design flaw I don't think I've seen one e46 that has a good effective gasket there still
Old 03-23-2013, 10:26 PM   #10
jskeets
jskeets's Avatar
interesting to hear.. thanks for the link madonthemike.
Old 02-23-2014, 08:07 PM   #11
rdhamill
My sockets corroded as well. I replaced the sockets with a 3LED circuit on each side.
I removed the LEDs from a trailer marker light.
I replaced the lenses and gaskets (ECS).
Lamp replacement cost all of $6.
Rick
05 330i ZHP
rdhamill is offline   Reply With Quote
