Old 01-09-2013, 08:45 PM   #1
Steven325e
Steven325e's Avatar
E36 Amp Bypass/delete
So I've been doing some searching, and all the answers I found were pretty convoluted. I have an aftermarket JVC deck in my E36, with stock amp (in the rear fender) and speakers.
My understanding is that the wiring is as per below:
JVC Deck -- (High level output) --> stock amp --> speakers
I would like to bypass and remove the stock amp, and connect the speakers directly to the deck using the existing stock wiring.
If I were to just splice the high level output from the deck, using the exisiting stock wiring, to the wires that come out of the amp to the speakers, I should be able to completely bypass the amp right? Is this possible or am I missing something?
CURRENT: 2005 Mazda 3 Sport GS - Black Mica | 1998 BMW 328i - Montrealblau-metallic
GONE: 1992 Mazda Miata - Classic Red | 1986 BMW 325e - Burgundrot-Metallic
Steven325e is offline   Reply With Quote
Old 01-09-2013, 09:32 PM   #2
TSI
Reverse Gear Member
Depends if the deck has its own integrated amp. Otherwise you'll get almost no sound...
Old 03-21-2013, 07:59 PM   #3
yes, you can remove your stock amp and bypass it. this will sound like shit if you have a standard amp that delivers ~50wrms per channel
