Old 08-30-2013, 08:30 AM   #76
Originally Posted by Yamahammer View Post
Nice design. I know its just a pre-lim but I would use a bolt/nut opposed to shaft/cotter where the cable end attaches to the actuating lever. I feel once its on the car getting the cotters through after potentially switching positions would be real tricky.
Have you checked linear displacement of the cable end at the actuator with it rotating on the secondary axis?
Yeah, I probably will end up using a shoulder bolt with a nylock nut.
I haven't checked it physically, but as I mentioned it has about a 45 degree sweep and I calculated the range of travel that the actuator will give me to be 0.75" to 1.5" of travel. Playing with the bike throttles, it looks like they only need about 1" to 1.25" of cable travel. So I think it should work.
Old 08-30-2013, 08:54 AM   #77
Yamahammer
Warlock of the century
Yamahammer's Avatar
Perfect. Okay neat. I can't wait to see this finished.
Just out of curiosity, how tight are your stock TB linkages? mine rocks around alot, to the point where the one piece will grind on the lower piece it tilts a bit. It is pretty annoying.
Old 08-30-2013, 09:35 AM   #78
Tight. You must be missing one of the bushings or something if it can rock around that much. I'll take a look at it on Sunday if I swing by berlin klassik.
Old 08-30-2013, 12:09 PM   #79
Yamahammer
Yamahammer's Avatar
Hmm ya something is not correct. I don't believe I ever took it apart even. Yeah that's the 8th. We can check it out then.
Old 08-30-2013, 01:03 PM   #80
You must have taken it apart to rotate the shaft 180 degrees so you can put on the variable TPS.
Old 08-30-2013, 09:02 PM   #81
Yamahammer
Yamahammer's Avatar
I didnt rotate the shaft, i run the TPS backwards.
Should maybe have done so. Putting the connector on would be easier.
Old 09-04-2013, 08:33 AM   #82
I took a few minutes yesterday to tack together the main part of the throttle assembly so I could test fit it on the motor with injectors, fuel rail and injector harness. Everything appears to be clear...
Old 09-04-2013, 09:51 AM   #83
BMe30
all by chance...
BMe30's Avatar
Its a beautiful thing
Gone but not forgotten
Old 09-04-2013, 10:11 AM   #84
Will it be on the car for the E30 cruise...that's the real question... of which I have no answer to lol
Old 09-04-2013, 10:37 AM   #85
BMe30
all by chance...
BMe30's Avatar
Im sure it will be.
I plan on having mine cleaned up, re installed, and tuned up for the meet. But nothing ever goes as planned now does it....
Old 09-04-2013, 10:47 AM   #86
SiR
Vtec just kicked in
looks pretty sweet.
bolt/nylock always come loose applications like that. I like your original idea.
-||Old Crayons||-
Old 09-04-2013, 11:56 AM   #87
Nope lol
What I end up using all depends on what costs money and what I can get for free lol
Old 09-04-2013, 05:28 PM   #88
aviator
Bolt with castle nut and cotter pin or aviation lock wire will stay put.
Looks like a nice mod. If I understand this correctly you are building this up as a track car but I'm curious what going to the 6 barrel set up is going to do to your fuel economy.
IK it's not typically a concern but the less time you spend pitting for fuel is more time racing.
fwiw I think those separate chrome filters would look sweet.
aviator is offline   Reply With Quote
Old 02-11-2014, 04:40 PM   #89
Wuzie
Wuzie's Avatar
All your pics are down!!
Wuzie is offline   Reply With Quote
Old 02-11-2014, 05:05 PM   #90
You can still open them up in a new tab... or just browse the album http://s575.photobucket.com/user/Ste...?sort=3&page=1
I was actually staring at the ITBs in the garage last night for a few minutes until the cold demotivated me from doing any work lol.
