Old 02-11-2013, 04:42 PM   #1
DET1990
blower motor
my blower motor stopped working so im putting in a new one in and i destroyed it taking the old one out how can i get the new one in with out breaking it
DET1990 is offline   Reply With Quote
Old 02-12-2013, 11:36 AM   #2
TSI
Reverse Gear Member
Um, generally speaking, be careful? Maybe lubriacate the points of contact, take your time and make sure you follow instructions to the letter...
Old 02-12-2013, 12:57 PM   #3
Burfy
Did you buy a pre assembled fan or get the one with removable cages?
Burfy is offline   Reply With Quote
Old 02-12-2013, 02:54 PM   #4
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
If you answer no, then you're ****ed. The one piece fans are an absolute nightmare, and require significant deflection of the cage to get it in. Must be VERY careful or else you will break them. The good news is that new plastic is much more ductile than 14+ year old plastic.
Old 02-12-2013, 03:20 PM   #5
DET1990
this is as far in as i can get it if i push it more i think itll break
Old 02-12-2013, 06:41 PM   #6
DET1990
Lol I ordered one with removable cages as I broke the used one I bought trying to put it in
Old 02-12-2013, 07:49 PM   #7
Axxe
Axxe's Avatar
Used = waste of time and money.
Old 02-12-2013, 07:51 PM   #8
DET1990
Learned the hard way
Old 02-12-2013, 08:09 PM   #9
Axxe
Axxe's Avatar
Typically the best lesson though, won't be easily forgotten. I thought I had the same issue back in the fall, turned out to be the clip that holds the plastic shield broke and jammed the blades. Dodged a bullet on that one. There is a specific method to putting it in, there is lots of info available online on it so make sure you read up on it.
