Old 02-21-2013, 01:29 PM   #1
sergiomordo
sergiomordo's Avatar
Disassembling and then reassembling of my engine...
Hi,
Does anyone know a shop that can fully disassemble and then reassemble my engine? I simply need to do some coating on some parts such as crank shaft, cam shaft, bearings etc for a university research. And then put the engine back together. Any help would be appreciated.
Thanks,
Sergio
sergiomordo is offline   Reply With Quote
Old 02-21-2013, 08:09 PM   #2
Dinanstu
Are there any trade schools locally that could use the opportunity for teaching and help you out? Just thinking that a full tear down and rebuild may be pricey at a shop.
Old 02-22-2013, 01:04 AM   #3
sergiomordo
That is a good idea actually, I will look into that. Thanks.
Old 02-22-2013, 01:50 PM   #4
DIY
Permanently Dirty
DIY's Avatar
You better make sure that you get the surfaces ground before you coat it or your bearings won't fit.. Or just see how big the bearings get ... I fear this isn't as simple as you hope... Also cam lobes musn't be increased or your final power results might be off
Old 02-23-2013, 03:14 AM   #5
sergiomordo
Thanks I will be careful with that. I did do coatings for race cars before for improved engine performance and durability. The coating is very thin, like microns. Also pre coating process actually takes away some material, so the change in size is very minimal. Does not create problems.
Old 02-24-2013, 11:28 AM   #6
DIY
Permanently Dirty
DIY's Avatar
cool, what kind of coating/process is it?
Old 02-25-2013, 09:15 PM   #7
sergiomordo
It is DLC coating (Diamond Like Carbon). Basically it reduces surface roughness which reduces friction coefficient. Also increases hardness so the parts life increases significantly and becomes highly scratch resistant. It also makes the part inert, which means it doesn't rust or anything.
