Old 01-29-2013, 07:46 PM   #1
gnome
on the roam
Need rear coolant hoses for e39 540i
Guys, need your help in identifying OEM part #'s for rear coolant hoses an e39 540i.
Was at the dealer last night... they couldn't find the hoses on the computer after half an hour, and they asked me to go to realoem to find them...
One of my hoses split while replacing my oil separator/CCV valve on the rear of the intake, and I notice 2 others were flimsy and looked like they are going to go soon.
The problem one is about 3 feet long, from the rear collector, around the drivers side, then loops back 180 degrees and attaches to a valve (heater valve?).
The other two are shorter heater hoses that attach near the firewall area driver's side.
Where can I get these hoses for a good price? Call Napa?
Even if I found the part # the dealer said I would have to order these...
TIA!
gnome is offline   Reply With Quote
Old 01-30-2013, 01:51 AM   #2
MLue1
MLue1's Avatar
Call Maranello BMW and speak to Mike they give a 20% discount to Maxbimmer Members. Ya I know clear as mud eh, I suggest tracing the hose(s) and see where it connects then use the diagram to figure out which one you need to order.
http://www.realoem.com/bmw/showparts...94&hg=64&fg=18
Mark
'99 E39 540iT
Old 01-30-2013, 09:05 AM   #3
Dinanstu
Call Mike at Parkview, he will actually find the parts....
Are these them?
http://realoem.com/bmw/showparts.do?...30&hg=64&fg=15
Old 01-30-2013, 10:01 PM   #4
MLue1
MLue1's Avatar
Are these them?
No those are the aluminum pipes that go from the heater core to the firewall.
Mark
'99 E39 540iT
Old 01-31-2013, 12:05 AM   #5
gnome
on the roam
Found them, after hours of searching forums, seems these can be prone to failure. Glad I am changing them while I have the ccv off.
05 HOSE F ENGINE INLET AND WATER VALVE 1 64218391005
08 HOSE F WATER VALVE AND RIGHT RADIATOR 1 64218391017
09 HOSE F WATER VALVE AND LEFT RADIATOR 1 64218367929
12 HOSE F RADIATOR AND ENGINE RETURN 1 64218391013.
Damn these are expensive. Placing my order...
Thanks for the input.
Old 01-31-2013, 12:26 AM   #6
MLue1
MLue1's Avatar
Great work others can use this info.
To be honest, a buddy of mine had a pin hole leak in one and we duct taped it for a few months before he replaced it with out issues.
Cheers!
Mark
'99 E39 540iT
