Old 01-28-2013, 10:02 AM   #1
635CSi
Almost Painted 6er
635CSi's Avatar
Send a message via MSN to 635CSi
Brand New Snap-on Verus Pro
Selling a brand new VERUS PRO with EURO package this is not a Verus, this tool is brand new only opened once by the Snap On Dealer to check if everything is there upon delivery, this is $11,075 plus taxes brand new I am asking $9500. Please PM or call me at 647-282-3874. This is brand new, never been used and comes with a warranty from Snap on.
Here are some details below,
VERUS PRO Diagnostic & Information System Features Stay connected to the vehicle and the internet while moving freely around the service bay
Ready faster – less than 30 seconds for VERUS PRO software suite to load
New thin-edge profile display tablet is 3 lbs lighter than previous model
Modular, dockable scope/meter with 9 ft USB cable for extended reach and portability
Expanded diagnostic suite now includes an online community that puts you in touch with the latest tips and expertise from technicians around the country
Genuine Windows® operating system for true multitasking
Shared vehicle ID – select the vehicle once for all diagnostic functions
Easy navigation - shows exactly the systems and tests available for the selected vehicle
Built-in browser and Wi-Fi to access your choice of web resources – parts suppliers, technical forums, repair information systems, OEM websites
Exclusive Snap-on Fast-Track® Troubleshooter provides millions of vehicle-specific code tips, symptom tips and timesavers for a faster repair
Industry-leading functions, tests and coverage previously found only in expensive factory tools
Avoid unnecessary parts replacement. Exclusive Fast-Track Guided Component Tests, component locator, known good values, and waveform library help verify good/bad components.
Display Tablet
Thin-profile tablet with 10" high-resolution 1024x600 touch screen for a detailed view
On-screen touch keyboard
Built-in camera to save and share photos for your repair records
User-programmable shortcut key for frequently used actions
Bluetooth® wireless and Wi-Fi to access your favorite web resources
High-energy lithium-ion battery pack for hours of continuous operation
USB, audio and auxiliary ports make it easy to add accessories
Big 250GB hard drive to save data and install your own applications
Software
Exclusive ShopStream™ integrated diagnostic suite with one-touch access to all major functions: scanner, scope, guided component tests, online expert forum, vehicle records, and the optional ShopKey® Repair Information System
Genuine Windows® multi-tasking to view multiple applications side-by-side
Configure display options, set triggers, record and playback results with the touch of your finger
Powerful data manager saves vehicle records, photos, technician notes, screen images, scanner and scope data
Scanner Module
Single keyless adapter for OBD-II vehicle applications – saves time
Connects wirelessly to the display tablet with Bluetooth® for remote operation
OEM-specific coverage for over 40 makes, as far back as 1980 (European optional)
Codes, live data, functional tests, relearns and adaptations for dozens of vehicle systems
Exclusive Fast-Track® Troubleshooter with millions of validated code tips, symptom tips and timesavers
Scope Module
More flexibility with the new hot-dockable scope module with 9 ft USB extension cord
High-speed 4-channel lab/ignition scope and digital/graphing meter
6 megasamples/second sample rate and glitch capture detects faults other scopes miss
Scale range: 0-100mV to 0-400V, 50kV secondary ignition
Sweep rate: 50 microseconds to 20 seconds (5 min in GMM mode) so you don’t miss a thing
Exclusive Fast-Track guided component tests for 40 domestic, Asian and European makes
VDC, VAC, ohms, frequency, duty cycle, pulse width, diode test and more
635CSi is offline   Reply With Quote
