Old 01-15-2013, 09:03 AM   #1
madonthemike
madonthemike's Avatar
Driver Side Mirror Glass Replacement
Is there any easy way of doing this, what i tried doing was tilt mirror all the way up and put a screw driver below to leverage it out, but it doesnt seem to be coming off - i feel like i might break something if i use excessive force.
madonthemike is offline   Reply With Quote
Old 01-20-2013, 03:48 PM   #2
Amit
Try something a bit wider like a 1" putty knife wrapped in tape.
Amit is offline   Reply With Quote
Old 01-20-2013, 06:52 PM   #3
jabela
It would be better to do it on a warm day. I'm waiting for a 5'C or better day, so as not to break anything.
www.maisonapothecare.ca
Old 01-03-2014, 02:29 PM   #4
Quickid
Where did you guys buy replacement glass?
Quickid is offline   Reply With Quote
Old 01-03-2014, 03:46 PM   #5
mrod
Only pull from the top or bottom or you will break the glass. Also when putting it back on push from the center preferably with a small block or something to even out the pressure.
Breaking a $120 mirror is not fun.
I found ECS tuning was the best price ($120) but there is a guy on kijiji that makes just the glass for like $40. You need to heat the old glass off the carrier.
mrod is offline   Reply With Quote
Old 01-03-2014, 07:58 PM   #6
Quickid
Thanks, I have been looking at ECS Tuning as well. Too bad there is no local place that sells OEM glass outside of the stealers.
Old 01-06-2014, 07:54 PM   #7
xlr8nbimbo
Pelican Parts has it and so does FCP Euro. Much less $$ than the stealership. It's very easy to install. I took off the old cracked mirror by looping a piece of twine around the mirror and giving it a tug - came off really easily. (A screwdriver is not the tool to use!) Reconnect the the wires from the old glass to the replacement glass and press in the new one with your hands. Piece of cake.
xlr8nbimbo is offline   Reply With Quote
Old 01-06-2014, 08:35 PM   #8
windwagen
windwagen's Avatar
The previous owner of my winter beater installed a stick-on replacement over the original glass. Even the heating still works. The only reason I know about it is that they installed it crooked and I can see the original glass. I don't know where they got it, but the shape is just right....
Tags
mirror glass replacement
