Old 01-10-2013, 05:38 PM   #1
G12
G12
K&n 2004 325i
When installing a k&n cold air intake when do you allocate the MAF sensor?
G12 is offline   Reply With Quote
Old 01-10-2013, 05:58 PM   #2
G12
G12
*where
Old 01-11-2013, 01:10 AM   #3
jabela
You shouldn't have to relocate the MAF. Also make sure not to over oil the filter, as it will gunk up the MAF.
2002 E46 325ci // 5spd // Sport Suspension
www.modernapothecary.ca
Old 01-11-2013, 01:16 AM   #4
jabela
ok, well if you have the one with the intake tube, then you put it between the tube and the filter wall.
Here's the instructions.
http://www.knfilters.com/instructions/57-1002_inst.pdf
http://www.knfilters.com/search/prod...x?Prod=57-1002
Old 01-11-2013, 06:59 PM   #5
G12
G12
Awesome thanks a lot man, I got it on today!
But I'm considering taking of the heat sheild because I don't think it's the right fit, do you think taking of the heat sheild would be okay?
Old 01-11-2013, 07:10 PM   #6
jabela
The heat shield is important because it keeps the hot engine air away from your intake. Without it you will lose horsepower and get lower mpg.
Old 01-11-2013, 07:22 PM   #7
G12
G12
Okay good to know, I might need to get a different heat sheild then. Thanks again!
Old 01-11-2013, 07:27 PM   #8
Barnsdale
Barnsdale's Avatar
Do you notice any difference after installing it? I thought about installing one of these for my 325i in the summer and never got around to it
Barnsdale is offline   Reply With Quote
Old 01-11-2013, 07:31 PM   #9
G12
G12
Well I took it for a spin just down the road and back. I cleaned my MAF sensor at the same time and I had more throttle response for sure and a bit more power. And it sounds damn killer! Well worth it man, just make sure that the kit you get has the right heat shield, the one I got has no hole for air hose coming from te center of the grill.
Old 01-12-2013, 12:14 AM   #10
ac_2007
Cruising in Top Gear
ac_2007's Avatar
Lol, I sold mine because you just lose power in the summer. The car will bog down on a warm day, especially noticeable when you're sitting in traffic.
Read your intake air temperature with the stock intake, and then the K&N.
Stock will read lower (Hint: colder air is better)
All you're paying for is sound. That's it!
Your kit should have come with 2 different plates for the heatshield.
One of them has the hole stamped through it, the other doesn't.
ac_2007 is online now   Reply With Quote
