Old 01-05-2013, 01:39 AM   #1
ASCE
Driver Side window not going up.
Hey guys,
I tried looking for an answer for this but no luck.
I have '01 330CI and My driver side window switch has been broken for a few months(it will go down but not back up). Since then I have been using the key method to raise the window when it went down. The other day I broke the cylinder in my lock and haven't been able to use that method either. I am looking for a new switch and a lock repair kit but in the mean time, is there any other way to raise the window?
The car is stuck in my garage for now.
ASCE is offline   Reply With Quote
Old 01-05-2013, 01:58 AM   #2
Blackedout95
Remove the door panel, disconnect and pull up.
E46
Old 01-05-2013, 01:58 AM   #3
Yes, and no.
It can be done with the remote, but only if it has the EURO programing done to it! (so very slight chances you have that option, worth trying tho!)
We have a used swich you can pick up and solve the problem right away, and next time fix ANY issues right away, before you have to fix MORE things!!!
Old 01-05-2013, 02:01 AM   #4
Not an option! You CAN NOT pull the window, and to disconnect from the motor/linkage you need move the glass at least twice!
Old 01-05-2013, 04:19 AM   #5
jabela
When my drivers window switch failed, I simply swapped the hardware with the rear window switch. You'll see how when you take it apart. Not too hard.
Eventually I replaced the whole module.
www.maisonapothecare.ca
Old 01-05-2013, 02:10 PM   #6
MANDD
Autobahn East
The window can be rolled up via the BMW tester (GM/ZKE), contact your personal BMW tech or one of the board sponsors.
Mark.
Old 01-05-2013, 09:21 PM   #7
Blackedout95
True but we do it all the time so may have assumed others can to. It helps to have another set of hands, cant hold the glass and disconnect at the same time with only two lol Glass will be on an angle etc.
E46
Old 01-08-2013, 03:30 AM   #8
On E36 yes, but the E46 is bolted on with the 8mm that can ONLY be accessed at ONE point, so unless you move it, or bust it, i dont know how it can be done!
We do it by powering the motor directly, but that might be tricky for some!
Old 01-08-2013, 08:03 AM   #9
Dinanstu
You should have got the replacement switch a long time ago...!
Don't turn this into a frankenstein repair, just get the swutch from Eurostyle and do it right...
Old 01-08-2013, 01:38 PM   #10
ASCE
I did get the my switch from Eurostyle on the weekend and it works like a charm! Working on my lock cylinder now. Thanks for the helps guys!
Old 01-08-2013, 06:13 PM   #11
Blackedout95
Ahh I see an e46, ya thought he had a e36.
E46
