Old 10-11-2012, 09:41 PM   #1
blackburn21
Issue with my e30
Hi!
I bought a e30 in june. It a 325i 1989. When i start my engine, he cranking like 8-10 sec before the engine run. What the problem?
And my fuel gauge don't work, so he flicking?
Sorry my english, i'm french from montreal!
blackburn21 is online now   Reply With Quote
Old 10-11-2012, 11:39 PM   #2
could be a number of things. check the fuel pressure regulator; check pump for adequate fuel pressure.
the fuel gauge problem may be a loose nut on the back of the gauge. tighten it down.
Old 10-12-2012, 01:16 AM   #3
blackburn21
You think is my fuel pump is the problem?
The nut on the back gauge is tight!
Old 10-12-2012, 07:59 AM   #4
then it is probably a faulty gauge - which you'll need to replace. OR...If you're fuel level switch in the tank is bad it may cause you to get a false reading on the gauge. And if that filter in the tank is clogged it may delay fuel delivery to the injectors.
Try changing your fuel filter first. cheapest and easiest fix first.
Old 10-12-2012, 10:32 AM   #5
blackburn21
Filter is new since last week, same problem.. for the gauge, i have changed, the second gauge flick too
Old 10-12-2012, 02:28 PM   #6
you might have a problem with the SI board inside the cluster. batteries usually go in those.
but you still haven't checked the sending unit in the gas tank have you?
Old 10-12-2012, 02:45 PM   #7
GeMc
GeMc's Avatar
Sending unit in fuel tank for guage problem. Change the fuel pump and regulator for startup issues.
German Mechanics
2530 Speers Rd #5
Oakville, ON Canada
(905) 286-4362
Mon-Fri 9am - 5pm
www.GermanMechanics.ca
Old 10-12-2012, 09:22 PM   #8
blackburn21
Sending unit come with the pomp if I buy a brand new?
Old 10-13-2012, 07:44 AM   #9
for an 89-325 -should come complete.
Old 10-14-2012, 11:19 AM   #10
I had the exact same problem with my old e30 sedan. It was the fuel pump being on its way out.
Old 10-29-2012, 08:45 PM   #11
e3049
Hey my 87 320i was doing the same thing...I fixed it by polishing up the grounding point next to the battery...it didn't look corroded and was very secure...but hitting it with some emery cloth made a huge difference in how the car starts....try it it's free
e3049 is offline   Reply With Quote
Old 11-28-2012, 03:22 PM   #12
blackburn21
So!
Have changing the sending unit.. the gauge flick again!
Startup issues:
Change the fuel pump, polishing the ground. The problem is not solved. I think change the fuel regulator
Old 11-28-2012, 03:31 PM   #13
The Twin
The Twin's Avatar
used fuel pumps are cheap, and very easy to replace.
as for the flicking gauge, it's all part of the beauty of E30 ownership.
I fix it with a heavyhanded whack to the dashboard.
Old 11-28-2012, 05:52 PM   #14
TSI
Reverse Gear Member
I find this works for most things in life...
Old 11-28-2012, 06:05 PM   #15
You'll learn the sweet spot and amount of force to inflict....repeatedly...
top of console works well for me
